Quantcast Making my own "raingler" nets - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Making my own "raingler" nets
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 03-09-2009, 07:59 AM   #31
tjsahara1979
Originally Posted by Dmcastino View Post
Why not just run a lighter over the ends instead of messing with glue?
I could but my house was built in 1918 and is a tinderbox. I figured paying a dollar or two for some antifray stuff was worth my house not burning down. I'm VERY accident prone
Originally Posted by Coyote56 View Post
Great job man,
I have been thinking of doing the same thing except using an old cargo net out of a C-130. Great work.
The cargo net they use for the seats? That was the first thing I thought about doing actually too. For me it came down to aesthetics. I just preferred the black over the OD. I'd be REALLY interested in seeing them when they're done though.
Originally Posted by benjamin.olejnik View Post
Where did you get your anti-fray glue, what kind is it? How did you apply it? What about dipping them in wax or something, I guess the wax might not stay on hot days. Also, did you go with the heavy polypro or the regular stuff?
I got the anti-fray glue from Joanne's Fabrics. Its this stuff:
It goes on just like superglue (just a little thicker). You can find it in any fabric or craft store. I ended up going with the heavy duty because it was only a few dollars more than the regular stuff for 50 yards.
Originally Posted by Dave Barry
There is a very fine line between "hobby" and "mental illness"
'01 TJ Sahara. 3" BDS lift, 1" PA BL, 33x12.50x15 Nokian Vatiiva M/Ts, Durango steering box, soft 8s, RE steering stabilizer, and one LOUD effin' train horn :)
Green Jeep Club Member #183
tjsahara1979 is offline   Reply With Quote
Old 03-09-2009, 08:38 AM   #32
Dean O
Those look great! Did you draw out a pattern or just lay it out with the webbing? I plan on making a set of nets myself, if you have any dimensions that you wouldn't mind sharing, it'd sure help a lot.
2000 4-dr Sport XJ- RED 3" lift, moabs and 31" MTs
'97 TJ Sport- BLACK-2" lift and 32"s
Dean O is offline   Reply With Quote
Old 03-09-2009, 09:00 AM   #33
tjsahara1979
Thanks for the feedback! I tried drawing out a pattern but it was just easier (especially if you're a hands-on person) to actually lay out the pattern.
As far as dimensions go, they were:
18" top to bottom
18" from the center of the "O" rings horizontal on the top
and 23" from the center of the "O" rings horizontal on the bottom.
Diagram:
From there, I just lined them up best I could. Take your time with them. It took quite a bit longer than I expected to do all of the sewing and alignment. I also started from the center and worked my way out so I'd maintain a constant pattern, because when they're pulled tight, any misalignments will really show.
Let me know if you have any other questions!
Old 03-09-2009, 09:12 AM   #34
tjsahara1979
I started on the top portion this weekend too. I think instead of doing one large section to go from the tailgate to windshield, I'm going to do two. One from the tailgate to the center roll bar and one from the center roll bar to the windshield. This will allow me to detach the net from the windshield and hang it down behind the seats to keep the dogs from getting into the front seat.
It'll also make it a lot easier to sew. The larger the sections get, the more a problem can expand. A small misalignment on one end will turn into a huge alignment issue on the other end if its a large section.
What do you all think? Good idea?
Old 03-09-2009, 09:21 AM   #35
Mike05TJ
Sounds like a great idea. I have a net to keep my Mutt in the back too. By the way the windows look great.
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
Mike05TJ is offline   Reply With Quote
Old 03-09-2009, 12:43 PM   #36
LoneJeeper
i wear foil underwear too
LoneJeeper's Avatar
The plastic loop adjusters are probably strong enough, but cam buckles would certainly be strong enough. I can stand on the nets in my jeep. I'm 6"3" 280#.
ಠ_ಠ
LoneJeeper is offline   Reply With Quote
Old 03-09-2009, 01:49 PM   #37
Coyote56
I was gonna try to get my buddy to find me an old net they were gonna dispose of and then I was actually going to try to dye it black somehow. Don't know what I would use to dye it with that would hold up. If I get it for free though it really doesn't matter too much if I jack it up. We will see if he is able to find me one, I will post pics.
Coyote56 is offline   Reply With Quote
Old 03-09-2009, 03:22 PM   #38
saylorjerry
I am begining my netting today. I picked up some tiedown straps from a local hardwaer store on clearance that should work at least for the sides. Your stuff looks great so far, can't wait to see the top portions.
Look to the sky just before you die...it's the last time you will.
saylorjerry is offline   Reply With Quote
Old 03-09-2009, 04:17 PM   #39
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Originally Posted by RKBA View Post
Great job; human beings are not meant to be specialists. We should be able to weld, program computers, butcher meat, shoot a gun, criticize literature, fix a car, balance a budget, paint a house, quote the Constitution, market a product, build a shed, tan leather, understand a contract, make speeches, etc., etc.
The more you can do yourself, the greater your chances of being successful.
I am on a similar track right now myself - finishing a Master's Degree and hand casting handgun bullets from scap lead in my spare time. My sons are currently prepping for a spring vegetable garden. They're throwing a recession; we aren't participating.
You might want to check out our newest addition to the JeepForum group of forums at:
http://www.preparedsociety.com
Doing exactly what you describe above ..
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
#1 From street to trail, '88 YJ on 38" tires does it all well
#2 Silver 2006 TJ Unlimited, zombie ready as the daily-driver
.. and now a Kawasaki KLR650 DualSport bike
TEOTWAWKI
NaeKid is online now   Reply With Quote
Old 03-09-2009, 06:47 PM   #40
Doctor7474
I was thinking about making some nets too, not to big on sewing but was bouncing around the idea of using pop rivets at each intersection....
Doctor7474 is offline   Reply With Quote
Old 03-09-2009, 07:35 PM   #41
NaeKid
NaeKid's Avatar
If you want to use rivets for holding everything together - visit a leather working shop (like Tandy Leather Factory to gather up the supplies including buckles, rings, etc. I think that they are fairly reasonable in price for their "make-it-yourself" projects.
TEOTWAWKI
Old 03-09-2009, 09:14 PM   #42
chorndawg
This is precisely why I wanted to do this. My fiance and I decided that we're going to start taking classes on all kinds of things like this. Our next class will be a simple welding course. After that, a class on cooking seafood. And after that, fine woodworking.
I can't wait! There's something incredibly satisfying about making something yourself.
And let's not forget candle making, needlepoint and stamp collecting Just kidding it looks great. Can't wait to see the finished product installed. Thanks for the look.
chorndawg is offline   Reply With Quote
Old 03-10-2009, 08:35 AM   #43
tjsahara1979
Well, I didnt get squat done last night. It came down to, would I rather sew or watch "the departed".
I'll definitely be working on it tomorrow though.
Old 03-10-2009, 10:20 AM   #44
her99TJ
This looks great. I may just have to do this for his Jeep to keep the dog inside!
Ashley
Her TJ
www.indyorv.com
her99TJ is offline   Reply With Quote
Old 03-10-2009, 10:36 AM   #45
tjsahara1979
Thats why I'm doing it
Glock Forum
