Making my own "raingler" nets
| Ruffstuff Axle Simple Swap Kit! | Truck-Lite's New LED Headlamp Series | Spartan Lockers FREE SHIPPING Excellent Prices |
#16 | ||
The more you can do yourself, the greater your chances of being successful. I am on a similar track right now myself - finishing a Master's Degree and hand casting handgun bullets from scap lead in my spare time. My sons are currently prepping for a spring vegetable garden. They're throwing a recession; we aren't participating.
2002 TJ SE 2004 WJ Laredo 4.7 2006 LJ 2007 Rockwood Freedom 2280 "...in the GOP, enthusiasm is measured in Reagan units." |
#17 | |
I'm going to be finishing the windows tonight. Hopefully I can do the entire top portion tomorrow. Anybody think they'd want to trade a Safari top and header channel for a pair of the windows? I can always make an extra set
I'll even customize the thread color to match your jeep. Yellow jeep + yellow thread would look pretty damn nice ![]()
Green Jeep Club Member #183 |
#18 | |
*Update*
I finished the windows last night and stuck them in this morning. If you guys are thinking about doing this, I HIGHLY suggest some type of anti-fray gel for the ends. Polypro frays like a mofo and will break them down. The stuff I got is almost like superglue. I love how they turned out so far. The dark green thread is really subtle unless you're up close. I can't wait to get to work on the top portion now! Here are some pics: ![]() ![]() ![]()
#19 |
Great job. I bought a pair of window nets used and need to make the rear. I have a industrial sewing machine but was looking to find the material. Here is a site that I found ... http://www.buyhookandloop.com/Webbing_Products.asp
Now I have to find the time...
04 Rubicon, RE 3.5" Super Flex, Tom Woods drive shafts, Old Man Emu Shocks, JKS bar pin eliminators, Daystar 1" body and motor mount lift , Olympic bumpers, Teraflex Steering box skid, Jeep Medic engine skid and tummy tuck, Shrockworks sliders, Powerslot rotors, Hawk brake pads, Spidertrax 1.5" wheel spacers, Borla cat-back exhaust, Airaid intake and throttle body spacer, Gen-right hood louvers, Optima red top battery, Bestop spare tire carrier, Skyjacker tie rod, Monroe steering stabilizer, Herculiner on the floor, OR-Fab sport cage, Kilby full length rack, Cobra CB and antenna, T-Max 9000 lb winch, A-Z Fabrication winch mount, Zenon 6" flares, custom fabed Stinger, Alpine stereo with JL audio sub and I-pod, Garmin with 08 TOPO, Viar on board air compressor... Etc... |
#20 |
those look really good and youre saving a lot of money and youre getting self pride so its an automatic win win
#21 | ||
They were AWESOME. VERY cheap (cheapest I found), almost half the price of that site and really fast shipping. Thanks!
#22 |
Where did you get your anti-fray glue, what kind is it? How did you apply it? What about dipping them in wax or something, I guess the wax might not stay on hot days. Also, did you go with the heavy polypro or the regular stuff?
#23 |
Why not just run a lighter over the ends instead of messing with glue?
#24 | |
That's what I was thinking, just burn the ends and be done with it. Great job on the nets though, they look very professional.
1998 TJ NRA Life Member |
#25 | |
Brake Wizard
The best way to do it is cut it to length with a hot knife that cuts and melts at the same time.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#26 | |
#27 | |
Brake Wizard
I used to own and run a shop making truck tarps, big industrial nets, trampoline repair and tent repair in another life.
#28 |
i do the lighter trick, or use a heat gun. once you do it a bunch of times you get the hang of it.
nice work, those nets look great!
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#29 |
You can also clamp down close to the end with a pair of needle nose, and let it burn back to the needle nose. That usually lets the material melt enough then put itself out leaving a nice clean edge.
#30 |
Great job man,
I have been thinking of doing the same thing except using an old cargo net out of a C-130. Great work. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
