Making Hummer Style Snorkel for TJ - JeepForum.com
post #1 of 8 Old 07-06-2012, 02:46 PM Thread Starter
Coffee1997TJ
So here is the theory. Remove air box completely and replace with inline spectre product. Then add 90 degree bend and up pipe to a precleaner. Perhaps the one from centri unless others have found a better one. This would build a RiverRenegadesc intake with out having to keep the old box with paper square filter design. Please give input I think I'm going to try this unless someone can talk me out of it.
http://www.quadratec.com/products/17006_7000_07.htm
http://www.centriprecleaner.com/specs.html
Coffee1997TJ is offline
post #2 of 8 Old 07-07-2012, 10:32 AM
stottman
Sounds cool, do it and take lots of pics
2000 Tj with 4" lift and and 33"s, she's a work in progress got some other perfomance mods as well.
F350 King Ranch Turbo Diesel on 35's
stottman is offline
post #3 of 8 Old 07-07-2012, 10:44 AM
LostJeeper
Im kinda working on same thing right now with spectre which has a air filter already. Im sitting inside the cowl just need to figure out how to do rest.
Armed Forces Jeeps
MT WAVE SAR
KF7IRO
LostJeeper is offline
post #4 of 8 Old 07-07-2012, 11:53 AM
Benderff
Benderff's Avatar
I'm getting rid of a Enginaire cap if you are interested. It's lower profile IIRC.
http://www.jeepforum.com/forum/f130/...e-cap-1373046/
Benderff is offline
post #5 of 8 Old 07-07-2012, 12:27 PM Thread Starter
Coffee1997TJ
Nice LostJeeper that is the route i want to take. It looks good on your rig. does it look like it can be sealed at least splash proof around where it pulls apart for cleaning the filter?
New Jeep Enthusiast.
1997 TJ Sahara, 33inch Cooper Discover, 6inch Suspension Lift
FJ40 will be missed but the four coil spring are a nice change.
post #6 of 8 Old 07-07-2012, 12:33 PM
DerekXJ
Take a look at my thread about the spectre intake..........Its still on the first page here. called.
"Spectre intake BIG problems" .......before you continue with this idea. Especially on your 97!
Check out and Comment my build thread!!!
DerekXJ is offline
post #7 of 8 Old 07-07-2012, 12:59 PM Thread Starter
Coffee1997TJ
Follow DerekXJ's post!!! Anyone following this post this is a major design flaw. Not one that will stop this project but needs attention. Anyone trying this mod need to consider completing the job in one go. If like me you were planning on doing it in stages we could end up Drowned like DerekXJ. The 90degree up turn as well as the precleaner will be needed to prevent this from happening.
Thank you for your post DerekXJ. This will still work but without the cap we are just begging to get hydolocked. I'm considering a water trap like on a sink or crapper with a drain plug to allow removal of water before it is ingested. I need to make some measurements to see if there is room. Though it should not be necessary with the precleaner on top.
post #8 of 8 Old 07-19-2012, 02:18 PM
DerekXJ
What are you referring to by a precleaner?
Putting a hummer snorkel in the cowl should eliminate ALL water from getting in!
DerekXJ is offline
diy , intake , pre-filter , snorkel
Hummer Snorkel?? 1murderedjeep YJ Wrangler Technical Forum 11 03-13-2012 07:12 AM
Hummer Snorkel Mod mgrammer Wrangler General Discussion 20 11-18-2008 09:45 PM
Hummer snorkel is in (Pics) cheesycook TJ Wrangler Technical Forum 32 05-08-2007 06:00 AM
Hummer Snorkel Jakemd98 TJ Wrangler Technical Forum 3 08-31-2006 06:20 AM
Hummer Snorkel JESSETHELJ TJ Wrangler Technical Forum 6 07-07-2006 09:01 AM
