MAJOR OBA PROBLEM! (Serp Belt TOO SHORT or otherwise won't fit!!)
| Official Chassis Saver Rust Preventive Truck & Auto Un | TJ 5.25" Speaker Adapters - NalinMFG | SALE -- Yukon Gear Free Spin Hub Conversion Kit - Dana 30 |
#1 | |
Serp Belt TOO SHORT or otherwise won't fit!! RESOLVED
I ordered
Is the belt too short because It's a gates knock-off, is this the correct belt? Can anything else move to give me more play to get it on? would pictures help? I'm kind-of desperate... I don't want to put the stock belt on without the york... this has been too long of a project to get held up because of a stupid belt issue!!!! HELP!!! EDIT: Thanks for the additional replies, but in my last post, I said I was able to get the correct belt! Thanks again for all the help everybody!
#2 |
i have a idea prob not the case but did u put the belt around the right way
#3 | |
http://kilbyenterprises.com/KE-1550.htm and more specifically: ![]() yes, but thanks!!! |
#4 |
Some Call me RockDog
I thought mine was too long at first. I didn't have it rooted the correct way. Go onto Kilby's forum on their website. Brad usually responds to every post by the next day.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt My Build Thread. www.kifourwheelers.com www.indyorv.com For Sale: TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss 35" procomp tires with Aluminum wheels $650 (4) 5x4.5 steel beadlocks $200 3 11"& 2 13" BBCS shocks Ford Dana 60 Rear $150 Big Daddy Offroad HD tie Rod (4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175 |
#5 |
I'd pull the idler for the adjustable one, route it up and see if your even close. It's pretty easy to run that tensioner the wrong way too, tightening instead of loosining. If you're sure its wrong, try one a bit longer, or loosen it up wrap string around the route and then measure the string. From there any auto parts place can generally help
#6 |
Posted on kilbyforums.com, Brad gave me parts numbers for 4 different sizes. Still ended up wrong! I got one 5" longer than with A/C. My part number is K060960 which comes in at 96-5/8" long. It fit like a charm... pumping air! Although pumping a TON of oil too, so I need to already empty my coalescing filter's cup after only pressurizing the tank twice! I need to keep 10W-30 with me to keep the york topped off too!
#7 |
Admin, Jeep in Pieces
I think that I put a 105" belt on my 2.5L w/OBA. Just measure the correct size (run a string through the pullys) and go to NAPA. Simple solution.
You can do things the right way or the wrong way. Or you can do it MY way...which is like the wrong way, only faster. Ramsey Winches | My Gallery | www.dakuda.com |
#8 |
Do it right or not at all
![]() Join Date: Jan 2003
I've even had length probs just replacing my OE serpentine belt. NAPA STILL has the wrong p/n for '97 4.0L with a/c engines in their database, I have to bring an old belt in pull the p/n from. It seems the belt manufacturers don't quite have their acts together. This is probably why I never bothered to convert my OBA to a serpentine belt, I figured there'd be a lot of grief figuring out the right length to use. I use a small fan belt off a double alternator pulley to drive my OBA.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#9 | |
#10 |
Just did my oba 3 weeks ago...A secret I did not know about belts...
The part number is thier size in inches. eg- NAPA part number 060910 is telling you it is a 6 rib 91 inch belt. If your belt is this belt(this is a TJ belt, I think) and it is too small, get the part number 060950, it will be 4 inches longer. I think I ended up with the 97.5 inch belt(P/N060975 of coarse) Hope this helps... This size in the part number is true with all makers, as far as I know. |
#11 | |
#12 | |
#13 | |
Lifted/Locked/Rolled/Sunk
I need a 35" tire for spare. PM me if you have something. My Hummer Hole video SIRA 4x4 club I'll be Savvy someday!
#14 | |
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
