MAF same as MAP sensor??? - JeepForum.com
post #1 of 22 Old 07-05-2010, 02:33 PM Thread Starter
BrandonRay
I used the search tool and checked my service manual but couldn't find anything. I threw a P0171 code... running lean on bank 1, so I wanted to clean the MAF sensor. Anyway I couldn't find it in the service manual index. All I found was a MAP (Maximum Absolute Pressure) sensor.
So I was wondering, is this just a new name for the Mass Air Flow sensor??? I have a 2005 LJ 4.0 I6.
Thanks
BrandonRay is offline
post #2 of 22 Old 07-05-2010, 02:49 PM
tknarr
No, Mass Airflow Sensor is usually found in the air intake system and measures airflow to the engine.
Manifold Absolute Pressure sensor is usually found in the intake manifold and measures vacuum? (anyone fell free to jump in here and correct me).
tknarr is offline
post #3 of 22 Old 07-05-2010, 04:34 PM Thread Starter
BrandonRay
Yeah Manifold Absolute Pressure not "Maximum"... sorry for the typo... anyway I can't find anything on the MAF in my service manual... I'd think that would be something worth listing in the index.. thank you for the input!
post #4 of 22 Old 07-05-2010, 04:37 PM
Sundowner
The MAP sensor works alongside the TPS to measure the amount of air coming into the engine, if I am not mistaken. It's a speed-density system, of sorts. No MAF sensor is needed.
Sundowner is offline
post #5 of 22 Old 07-05-2010, 04:37 PM
Sweeney
Well, your Jeep doesn't have a MAF sensor.
Sweeney is offline
post #6 of 22 Old 07-05-2010, 04:41 PM
joshr1987
joshr1987's Avatar
Yeah, while they are not the same, the do serve the same purpose. You wouldnt have both...
joshr1987 is offline
post #7 of 22 Old 07-05-2010, 04:56 PM
Sundowner
Well, kind of...so, just for the sake of clarity:
MAF directly measures the mass of the air that is entering the engine, and the computer adds fuel accordingly.
MAP measures the pressure of the air that's in the manifold...i.e. air density...and correlates that value with the computer and the throttle position at the time, which allows the computer to know how much air is actually entering the manifold; the computer then adds fuel accordingly. It's sort of an extra step in the process, so to speak.
So yes, in that they both serve the purpose of measuring how much air goes through the manifold, they are very similar. However, it's not quite accurate to say that they serve the same purpose, as they are designed for totally different applications.
post #8 of 22 Old 07-05-2010, 05:08 PM Thread Starter
BrandonRay
Yeah it doesn't seem like I'd need both... so I guess I'll clean the MAP and hope the MIL stays off and the MPG's improve a little.
post #9 of 22 Old 07-05-2010, 05:16 PM Thread Starter
BrandonRay
This is a little of what I found..
The MAP sensor is used as an input to the Powertrain
Control Module (PCM). It contains a silicon
based sensing unit to provide data on the manifold
vacuum that draws the air/fuel mixture into the combustion
chamber. The PCM requires this information
to determine injector pulse width and spark advance.
When manifold absolute pressure (MAP) equals
Barometric pressure, the pulse width will be at maximum.
post #10 of 22 Old 07-05-2010, 07:00 PM
Sundowner
P0171 can also be caused by low fuel pressure, and at times by a vacuum leak. The Bank 1 lean condition is detected by the upstream Bank 1 O2 sensor, and all it's telling you is that for one reason or another, it thinks you have too much air and/or not enough fuel in the front half of the engine. The MAF sensor - in this case, not present - may or may not have anything to do with it.
post #11 of 22 Old 07-05-2010, 07:20 PM Thread Starter
BrandonRay
Yeah my basic plan is to clean the MAP sensor, then replace if that doesn't work, if I still have the issue move on to checking the vacuum and PCV hoses, then the fuel filter, and the fuel pressure. Let me know if that sounds like the right path to take... I'm just learning here.
post #12 of 22 Old 07-05-2010, 07:37 PM
Sundowner
No offense, but why are you going to spend money on a new sensor before you check things that will cost you nothing? Looking over the vacuum lines and checking your fuel filter and fuel pressure costs you exactly $0. I promise a new MAP sensor will cost more than that.
post #13 of 22 Old 07-05-2010, 08:01 PM Thread Starter
BrandonRay
Hopefully that pic goes through... if it does is that not a MAF on the air intake tube between the air filter housing and the throttle body? You can see the MAP in the bottom of the pic next to the throttle body.
post #14 of 22 Old 07-05-2010, 08:05 PM Thread Starter
BrandonRay
None taken... the MAP's just under $20, and I wasn't sure what a PIA it would be to find a leak somewhere else... I haven't done it before. I was just thinking systematically.
post #15 of 22 Old 07-05-2010, 08:05 PM
Sundowner
I don't see any picture, but I don't need to. You don't have one. Trust us.
p0171 , lj , wrangler , maf , map , sensor
Very confused! banck two sensor two oxygen sensor imnotaniceboy TJ Wrangler Technical Forum 5 03-12-2010 05:22 AM
Crankshaft position sensor and o2 sensor bracket help diy4x4 TJ Wrangler Technical Forum 0 03-02-2009 05:07 PM
My 2.5 takes a while to start, is it the cam sensor or crank sensor!! Divebum TJ Wrangler Technical Forum 9 12-24-2008 01:38 PM
power steering sensor needed? O2 sensor? Zorm YJ Wrangler Technical Forum 8 01-17-2008 09:06 AM
P0135; 02 Sensor Heater Malfunction, Sensor bad???? perley03 TJ Wrangler Technical Forum 5 01-18-2007 09:40 PM
