Machining Canyon center hole? - JeepForum.com
post #1 of 2 Old 10-19-2005, 07:30 PM Thread Starter
jeffjeep1
jeffjeep1's Avatar
I thought about putting a set of Canyons on a trailer I pull around with my TJ. I would need to enlarge the center hole to fit over the trailer's bearing dust cap. It looks like just the ring that retains the JEEP center cap needs to be removed, the balance of the center hole is large enough.
Has anybody done this?
What about fitting the Canyon wheel over a Warn "small" front hub conversion?
Yes, I know it is a casting and the potential issues with cast aluminum and casting defects.
Thanks
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #2 of 2 Old 10-19-2005, 07:33 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It'd cost an arm and a leg to machine out that hole on two wheels. It'd be better to just find wheels that fit without need for machining. Neither my steel wheels nor my aluminum AR23 wheels needed any machining to fit over my Warn hubs. The hole needs to be 2.78" or bigger to fit over the Warn 5x4.5" hub kit.
Jerry Bransford is online now
The center console is a black hole! Alexia Wrangler General Discussion 6 12-06-2008 11:05 PM
Currie Rear Boomerang shackles-- Hole spacing center to center? Burlbook48 YJ Wrangler Technical Forum 2 05-10-2008 07:32 PM
Wheel Center 3rd Brake Light on stock Canyon wheels? SpeedyMitch TJ Wrangler Technical Forum 2 11-01-2007 09:01 AM
Canyon Wheel Center Inserts Stolen! Laxtrainer TJ Wrangler Technical Forum 1 04-05-2005 09:31 AM
