Lucas Xtra heavy grease - JeepForum.com
post #1 of 7 Old 02-06-2008, 09:06 PM Thread Starter
Nonya
I bought some Lucas Xtra heavy grease to replace the moly grease i was using in the jeeps frt end joints.Now comes the unhappy part,after using this for about 6 months my ball joints have lots play in them.Anyone else using this green Lucas grease and did you have trouble?
I'm going to switch back to the moly grease i was buying from walmart.I've used it for years and never ever had a worn joint.I guess i made a stupid mistake thinking the Lucas grease was as good as their fuel additive.
Nonya is offline
post #2 of 7 Old 02-06-2008, 09:12 PM
2jhanna
very basic rule "if it ain't broke, don't fix it".
jhanna
denton county, tx
2jhanna is offline
post #3 of 7 Old 02-06-2008, 09:15 PM
Humboldt
Humboldt's Avatar
Lucas red and tacky is awesome. I havent used anything but it on the last 4 jeeps I have owned. (I figure if I cant even wipe it off my skin, or steam clean it off the carport..it's going to hold in a joint pretty well )
Humboldt is offline
post #4 of 7 Old 02-06-2008, 09:19 PM Thread Starter
Nonya
What can i say...what really frosts me is i recommended the moly grease to a friend of mine a few years ago after he had constant ball joint failures!It fixed his trouble and he had no more failures.Now i go and switch and get snake bit.I'm a IDGET!
Nonya is offline
post #5 of 7 Old 02-06-2008, 09:39 PM
alvinl
alvinl's Avatar
x2 It's great stuff. Ive used it for a few years now.
alvinl is offline
post #6 of 7 Old 02-06-2008, 10:28 PM Thread Starter
Nonya
I'm not using the red and tacky,its the green Xtra i bought.Anyone know the max allowable ball joint wear measurement before i look it up?
Nonya is offline
post #7 of 7 Old 02-06-2008, 11:11 PM Thread Starter
Nonya
Hmmm after looking through the 98 service manual i can't find any info on the max amount of ball joint play.
Nonya is offline
Advice Needed: Red Grease, Marine Grease, Synthetic Grease, Marine Synthetic mixes CB3 TJ Wrangler Technical Forum 5 11-25-2009 12:21 AM
OME HK (Heavy Duty) Suspension Kit- Launch Time Without Heavy Bumper? hikerpaddler TJ Wrangler Technical Forum 8 03-11-2009 11:50 AM
To grease or not to grease...U-Joints planedog YJ Wrangler Technical Forum 8 03-10-2009 07:43 PM
Mixing syn grease with dino grease jeepster93 YJ Wrangler Technical Forum 3 08-30-2007 01:59 PM
Grease fittings not releasing grease?? Perspex TJ Wrangler Technical Forum 3 08-10-2007 09:37 AM
