Lubricating RE heim joint - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Lubricating RE heim joint
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 03-12-2006, 06:44 AM   #1
ImaginaryFriend
ImaginaryFriend's Avatar
How do I lubricate or otherwise maintain the heim joint of the RE 1600 adjustable track bar?
ImaginaryFriend is offline   Reply With Quote
Unread 03-12-2006, 06:53 AM   #2
river rat
Forum porn star...I guess
river rat's Avatar
I don't think you do.
97 TJ. Full width D60 w/Detroit, Alloys and 5.89 gears. Full width D44 spooled, 60 outers, Warn lockouts. 6" Rock Krawler Gen II LA. 11 gallon cell behind the rear seat. 37" Maxxis Trepador competitions on 17" Stazworks double internals, blazay, blazay.....
river rat is offline   Reply With Quote
Unread 03-12-2006, 07:26 AM   #3
thejafe
After a day on the trail I usually develop a popping sound from the heim joint on my RE 1600. What I do is hit it with WD40 to help clean the mud and gunk off. THEN I hit it with White Lithium Grease in a spray can. That does the trick everytime .
thejafe is offline   Reply With Quote
Unread 03-12-2006, 08:00 AM   #4
Conn
i use chain wax available from any motorcycle shop. supposedly sticks better on "warmed" parts (ie motorcycle chains), but it's still sticky as heck, so it stays put and it lubes.
Conn is offline   Reply With Quote
Unread 03-12-2006, 08:51 AM   #5
bryans98tj
Yeah the 1600 heims are not greasable (internally) so they only thing you can do is spray them. I would hose mine down too with WD-40 then use lithium grease.
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote
Unread 03-12-2006, 09:54 AM   #6
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Just make sure to NOT just use WD-40 which will rinse any remaining lube out and then evaporate in a few days leaving nothing.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 03-12-2006, 12:58 PM   #7
BlueFlame
They don't need lubed, and spraying any kind of oil or grease on them will attract dirt and cause them to wear sooner. Either ignore them, or wipe them off by hand. If you feel you must lube, use silicone spray to hose them off. The residue is dry and won't hold dirt.
BlueFlame is offline   Reply With Quote
