lubricant types! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > lubricant types!
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-29-2015, 11:52 AM   #1
Mikeyc911
lubricant types!
snagged an 06 Rubicon and wanted to change all the fluids before it gets nice out, any specific brand? I use Mobil 1 for everything else i just don't know if there is something better.
Engine oil?
Diff/Axel oil?
Tranny oil?
Suggestions Please....
Mikeyc911 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2015, 01:02 PM   #2
JBTJ
Yep, you already said your answer.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 01-29-2015, 01:18 PM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I don't believe Mobil-1 makes an actual transmission lube that is suitable for any of the transmissions in our Jeeps. Their 75W-90 is the type of GL-5 gear lube that is not safe for use in a manual transmission and while Mobil makes ATF+4 as the automatic requires, Mobil-1 does not have ATF+4 in their stable.
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 01-29-2015, 01:48 PM   #4
Mikeyc911
Ok, what would you guys suggest for the manual Tranny?
Unread 01-29-2015, 02:57 PM   #5
Jerry Bransford
Administrator
Redline MTL which you can get at a discount from http://www.summitracing.com/parts/red-50204
Getting Savvy...
Unread 01-29-2015, 03:41 PM   #6
danielbuck
I put in there what ever is cheapest, haha
And the right weight.
Daniel Buck - [URL="http://www.danielbuck.net"]www.DanielBuck.net[/URL] - [URL="http://www.dnsfail.com"]www.DNSFAIL.com[/URL]
danielbuck is offline   Reply With Quote Quick reply to this message
Unread 01-29-2015, 10:53 PM   #7
geroux
I use Penzoil synchromesh in my 5-speed, 10W-30 Castrol syntech blend in the engine.
In the Rubi factory diffs use 75W-140 full synthetic with no additives. I use Mobil 1.
I use MOPAR ATF-4 in the transfer case.
geroux is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 02:04 AM   #8
cvaria
cvaria's Avatar
I just put mt90 in my transmission and redline atf in the transfer case.
The guy that dumped it all in (im not home to do my own work) said Chrysler updated the fluid teqs in 2004 the 10w30 for the ax5 and ax15. I refused. He maybe right but im scared of that
I like my 2003 Z4 2.5i... but love my 2002 Wrangler SE and my 2007 sportster 883/1200 conversion! :rofl:
cvaria is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 09:15 AM   #9
chris142
I like Royal Purple's synchromax myself.
chris142 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 09:40 AM   #10
Athensdawgs81
^^x2 on the RP synchromax. I just did my tranny and Amazon had the best price. And don't forget you'll need a bottle pump.
Fluid
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Pump
Athensdawgs81 is offline   Reply With Quote Quick reply to this message
Unread 01-30-2015, 11:01 AM   #11
Jerry Bransford
Administrator
He was correct. Know that 10W-30 motor oil has essentially the same viscosity as 75W-90 gear lube. They are measured in two different viscosity scales. I'd rather run Redline MT-90 in those transmissions though.
Getting Savvy...
Unread 01-30-2015, 11:33 AM   #12
Mikeyc911
Thanks for the help guys. do we have a link somewhere in the forum that has the capacities for the tranny and diffs?
Unread 01-30-2015, 12:33 PM   #13
2jhanna
http://www.jeepforum.com/forum/f9/fa...cities-489932/
jhanna
denton county, tx
2jhanna is offline   Reply With Quote Quick reply to this message
