Lube points??? - JeepForum.com
post #1 of 9 Old 11-29-2004, 02:45 PM Thread Starter
Houston Terrell
Lube points???
Are there points that i need to lube after playing in the mud/water?? im sure there is but i dont know where they are and do they have fittings where u can simply get a grease gun on them and shoot ??? sorry for the newb question.. im about to change the oil and figure while im doing that i can lube it up! thankee
Houston Terrell is offline
post #2 of 9 Old 11-29-2004, 03:05 PM
Stu Olson
Stu Olson's Avatar
Yes, there are grease fittings that should be serviced each time you do an oil change (or more often if necessary).
Bookmark this link...
http://www.stu-offroad.com/misc/maint.htm
because it gets you to lots of write-ups with photos like this...
that will help you with your various Jeep projects.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #3 of 9 Old 11-29-2004, 03:05 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
there are 7 in the front with zerk fittings that a normal grease gun work on...
it's in the FAQ at the top of the page that you should read...(although the pics don't seem to be active anymore, the list is there)...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #4 of 9 Old 11-29-2004, 04:39 PM Thread Starter
Houston Terrell
WOW thanks just what i was looking for... my jeep has 29k on it and im sure nothing has been changed Cept oil so ima change Oil tranny and dif fluids and lube since i have had water up to the doors a few times recently
post #5 of 9 Old 11-29-2004, 04:52 PM
SHNIPE
SHNIPE's Avatar
Stu how easy is it to replace those bushings in this pic
and also the one on the bottom left here
Mine are leaking and in bad shape and in need of replacing quickly. Wheres the best place for replacements?
Thanks in advance
Dennis
Black Jeep Club V.2 #78 or #98 or #108 a hell its too screwed up to know for sure so im takin #111 damnit!
SHNIPE is offline
post #6 of 9 Old 11-29-2004, 05:49 PM
0IIIIII0
0IIIIII0's Avatar
so if grease comes out the sides whene greasing these joints, they need changing???
i dont see how grease cant come out, especially if you grease it every oil change like i do...the old grease has to go somewhere...
98' TJ sahara-white w/spice hard top-5 spd-I6-all stock
70' CJ5 "Dauntless V-6"-3 spd-twin stick pto ramsey 8000lb winch-green body/black bikini/aluminum hard top-2" lift-mudders
0IIIIII0 is offline
post #7 of 9 Old 11-29-2004, 06:06 PM
blupupher
blupupher's Avatar
Some grease will come out. Don't grease them so much. I grease mine till they "pooch" a little, sometimes they leak out, I just wipe off the extra.
You can get the bushings at any autoparts store for pretty cheap, but the trick is getting the old one off and new one on, you need a pickle fork to get them apart.
blupupher is offline
post #8 of 9 Old 11-29-2004, 07:21 PM
Keith_C
Is there anything to grease on the front driveshaft ?
Keith_C is offline
post #9 of 9 Old 11-29-2004, 07:43 PM
blupupher
blupupher's Avatar
The 7 listed in Stu's site are the only ones on a stock TJ.
lube points CreepJeep JK Wrangler Technical Forum 3 07-28-2008 07:32 PM
Lube points billy boy TJ Wrangler Technical Forum 2 10-13-2006 10:27 AM
Lube points? Jakked TJ Wrangler Technical Forum 5 09-10-2006 02:13 PM
lube points Jeepin_Al TJ Wrangler Technical Forum 6 10-24-2004 06:45 PM
Lube Points WRFD17 TJ Wrangler Technical Forum 1 07-13-2004 08:08 PM
