LT1 swap Transfer case - JeepForum.com
post #1 of 4 Old 01-27-2011, 03:15 PM Thread Starter
brkeep
I'm getting ready for my LT1 swap, I'm mating it to a 700r4. My question is what transfer case should I use? Should I keep my current NP231 and use the adapter from Advance, or should I get an np231c out of a Blazer that bolts right up to the 700r4. I understand the advantages of the Chevy transfer case but I can't find one with a mechanical speedometer, only electric. Is there a year and truck to look for in a junkyard that has a Chevy t-case with a mechanical speedo?
brkeep is offline
post #2 of 4 Old 01-27-2011, 03:33 PM
Max-Q
1983 CJ7
Sorry I can't help you on the TC. Make a build thread with lots of pics please. I'm really interested in seeing what route you take with this. I'm swapping a SBC 383 with TPI and a 700R4 from a 1990 Vette into my CJ. Luckily I already have a Dana 300 tranny so I don't have to worry about that issue.
Do you have emissions where you live? If so, how are you going to deal with that? We only have emissions here for 96 and newer vehicles so I'm not willing to mess around with my TJ.
Good luck with your build.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #3 of 4 Old 01-27-2011, 03:44 PM Thread Starter
brkeep
I plan on taking a ton of pictures, I bought a new camera before I bought the engine and transmission. I'm in Phoenix so we do have pretty strict emissions here. The motor is out of a 94 Corvette and we don't have the year restrictions here, I can put a 94 engine into a 99 Jeep and still be compliant.
brkeep is offline
post #4 of 4 Old 01-27-2011, 06:55 PM Thread Starter
brkeep
Wow I feel dumb now, just figured out TJ's have electric speedos. Because I replaced the gear after my tires I assumed it was mechanical. Anyone done this t-case swap before?
brkeep is offline
Transfer case swap dadstjaz TJ Wrangler Technical Forum 8 11-19-2014 08:07 AM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
Swap transfer case xinys JK Wrangler Technical Forum 4 06-23-2009 07:00 AM
transfer case swap? 01silverTJ TJ Wrangler Technical Forum 2 07-08-2008 08:12 PM
transfer case swap michigan_mudder YJ Wrangler Technical Forum 2 03-20-2008 03:45 PM
