LSD For Front Rubicon Locking Axle - JeepForum.com
post #1 of 28 Old 12-19-2008, 07:13 PM Thread Starter
my05rubi
I drive in a lot of snow and know that locking the front axle is useless, no steering. But would like more traction from the front wheels in 4wd.
Is there a LSD that can be installed with a Rubicon front locking axle? Like a geared Tru-trac LSD?
Can a rear Rubicon LSD/locking axle assembly be installed in the front Rubicon axle?
my05rubi is offline
post #2 of 28 Old 12-19-2008, 07:26 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Are you speaking of 4wh low or 4wh high?
GOLENJEEPTJ is offline
post #3 of 28 Old 12-19-2008, 07:29 PM
GOLENJEEPTJ
You need to look under the article section up above on your toolbar! Hit that link and scroll down to the Bypass of Factory Locker Switch article!
post #4 of 28 Old 12-19-2008, 08:10 PM
roadkill
you can swap the front to the rear and vice versa. lots of Rubi owners have swapped out the rear unit in favor of the stronger front rubi case.
roadkill is offline
post #5 of 28 Old 12-19-2008, 08:25 PM
QuickSilverCon
he says he doesn't want to lock the front, because of the difficulty steering.
You SHOULD be able to purchase a rear LSD/locker and install it in your front, but the rear locker is known to be weaker.
Originally Posted by timberwolf0122 View Post
I think you are confusing the right to free speech with the right to be a **** bag, only one is protected by the constitution.
QuickSilverCon is offline
post #6 of 28 Old 12-19-2008, 09:32 PM
jdragger
I thought the TJ Rubi's had a tru track style LSD when the air locker wasn't engaged and that the electrics in the JK were open. Or is that only on aftermarket air lockers?
jdragger is offline
post #7 of 28 Old 12-19-2008, 09:54 PM
roadkill
my Rubi has a 4 high. he doesn't want a locker, he has that already. he wants to add a LSD and a locker. the easiest (only way that I can think of) is to swap his carrier with a rear carrier from a TJ Rubi.
jdragger, the TJ Rubis has open/locked diffs in front and a LSD/locked diff in rear, all air operated. from what I understand the electric JK Rubi lockers are all open/locked regardless of which diff (front or rear) its in
roadkill is offline
post #8 of 28 Old 12-19-2008, 09:59 PM
jdragger
Got it. Thanks. So my05rubi can accomplish steerable LSD with a rear locker in the front. Right?
jdragger is offline
post #9 of 28 Old 12-20-2008, 06:34 AM
roadkill
thats right but the rear LSD/locker on the rubis is known to be weaker than the front open/locked carrier
roadkill is offline
post #10 of 28 Old 12-20-2008, 06:57 AM Thread Starter
my05rubi
Even though the rear may be weaker, I don't thrash it around that much in rocks, etc, so putting a rear Rubi LSD/locker in the front, may be the plan.
Thanks for the input.
my05rubi is offline
post #11 of 28 Old 12-20-2008, 07:46 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you dont want a LSD in front. you want what you have, a full open or fully locked locker on a switch. a LSD front will be much worse in the snow.
you should always drive in snow on the street fully unlocked.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #12 of 28 Old 12-20-2008, 07:51 AM
never monday
I can't recommend an LSD for a front axle.
For years I auto crossed and road raced Hondas. We would run an 80% limited slip in them. In the rain it was a hand full. Even if you wanted to turn the car would go straight. I can't imagine how it would be in snow and ice.
Being locked or limited int he rear is easier to deal with in a low traction situation. The truck will be predictable in how it steps out to a fish tail and you can catch it.
never monday is offline
post #13 of 28 Old 12-20-2008, 09:00 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
An LSD will be much worse in front in the snow than what? The Detroit Truetrac LSD when in the front, rear, or both axles is excellent on snow or ice.
Jerry Bransford is online now
post #14 of 28 Old 12-20-2008, 03:52 PM
BlueFlame
BlueFlame's Avatar
Total agreement. I have run lsd in front, and in the winter I did NOT like it. Bad handling characteristics.
I'd never do it again, unless it was a truetrac.
Selectable open/locker is the best of both worlds.
BlueFlame is offline
post #15 of 28 Old 12-20-2008, 05:49 PM
Unlimited04
LSD will be much worse in snow than an open diff (or selectable locker) in a Jeep. You don't have to drive on ice covered roads with your LSDs front and rear. Selectable lockers are the best of both worlds, we're not talking about viscous coupling differentials with variable torque distributions here.
Useful Write-Ups:
Funny:
hood latch opinions needed. locking side latches vs locking front Snydermann TJ Wrangler Technical Forum 19 06-07-2014 04:39 AM
Could somebody list the plus's and minus's of locking front axle permanently on YJ gary1 YJ Wrangler Technical Forum 9 01-27-2010 06:13 PM
locking hub-front axle disconect Goobersbro YJ Wrangler Technical Forum 4 11-13-2008 10:32 PM
Locking front axle and drivability Pointblank TJ Wrangler Technical Forum 8 11-17-2006 07:03 PM
Locking my front axle. A few questions quitelifted TJ Wrangler Technical Forum 5 03-18-2006 08:39 PM
