LSD diff and Anti-spin diff... What's the difference? - JeepForum.com
post #1 of 8 Old 09-03-2010, 07:10 PM Thread Starter
TeeJay00
I have allways thought that my TJ had an LSD rear diff. I was just reading the build sheet I got from the dealership and it says DSAP Anti-Spin Differential Rear Axle. So is this also an LSD diff or what?
Also I have noticed that the front D30 carrier looks exactly the same as the rear D44 carrier and spider gears! I mean there are no clutches or anything else in my rear "Anti-Spin" D44 it looks like a normal open diff.
How does this Anti-Spin system work???
And how can I test it?
TeeJay00 is offline
post #2 of 8 Old 09-04-2010, 09:30 AM Thread Starter
TeeJay00
TeeJay00 is offline
post #3 of 8 Old 09-04-2010, 09:34 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That "Anti-Spin" is another term for the optional (extra cost) Tracloc limited slip differential your TJ apparently has. Your front axle is a Dana 30. It looks a lot like the Dana 44 but it's not. And the front Dana 30 is always open, it never comes with any kind of limited slip differential or locker.
Gone on vacation until August 25.
Jerry Bransford is offline
post #4 of 8 Old 09-04-2010, 09:38 AM Thread Starter
TeeJay00
But where is the Tracloc mechanism? Where are the parts in my rear carrier that does this? It just looks as an open diff. Normal carrier, normal spider gears and normal open diff setup!!!
How can I test it to see if it's working or not?
TeeJay00 is offline
post #5 of 8 Old 09-04-2010, 09:49 AM
Jerry Bransford
Administrator
IF you do indeed have the Traclock, it is just tucked into the side of the inside of the carrier. You will still see the spider gears inside the carrier. they are still present with the Tracloc.
Jack up the rear axle and spin one of the tires. If the other tire spins in the same direction, the Tracloc is still at least partially functional. If the other tire spins in the opposite direction, either the Tracloc's clutch pack is worn out or there is no Tracloc LSD present.
In the below photo, the carrier on the left is open. The carrier on the right is the Tracloc carrier.
post #6 of 8 Old 09-04-2010, 09:53 AM Thread Starter
TeeJay00
I don't think it moves in the same direction. As I recall it spens in the opposite direction. Allways has been this way What should I do now?? I have to fix it, right?
TeeJay00 is offline
post #7 of 8 Old 09-04-2010, 10:03 AM
Jerry Bransford
Administrator
If you have the carrier on the right which verifies you have the Tracloc LSD, its clutch pack can be replaced to restore it back to operation. Doing so won't be all that cheap to do however.
However, the Tracloc is not that good of a LSD to begin with and for the cost of rebuilding it, I would replace it with the much better Detroit Truetrac LSD. The Detroit Truetrac is gear based so it does not need or use a clutch pack that wears out like the Tracloc does. The Detroit Truetrac will hold up much better too, it is a much (!) better performing LSD than any other LSD out there.
post #8 of 8 Old 09-04-2010, 10:07 AM Thread Starter
TeeJay00
I get your point Jerry and thanks for the advice and info
I will look into replacing the whole system as you advised. I'm still waiting on my front aussie locker to arrive. So I will be getting into the rear diff right after I finish up the front
Man it just never ends with jeep builds, does it?
TeeJay00 is offline
Rugged Ridge Diff Skid vs. Riddler diff Cover 1398653 TJ Wrangler Technical Forum 3 01-10-2010 02:50 PM
Rockcrusher or Solid diff cover. Is there a difference? SteelBlueTJ TJ Wrangler Technical Forum 30 09-30-2009 12:15 PM
Replaced diff fluids, noticed color difference BlackBellamy TJ Wrangler Technical Forum 4 10-29-2007 11:28 AM
open diff? Wheels spin opposite quitelifted TJ Wrangler Technical Forum 4 03-05-2006 11:09 PM
Diff Skid/Axle truss for D35? (Slider for front of Rear Diff) BNovak TJ Wrangler Technical Forum 0 08-03-2004 11:04 PM
