Quantcast Ls1 Single turbo TJ - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Ls1 Single turbo TJ
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-17-2009, 11:43 AM   #46
ScJeepaholic
Is it a closed loop ls1 or if I replace the whole drivetrain and comp will an open loop "pre-owned" LS1 work?
[quote][color=black][FONT="Franklin Gothic Medium"][I]"What good fortune for governments that the people do not think."
Former Tyrannical German Furher
[/I][/FONT][/color][/quote]
[CENTER][COLOR="White"][FONT="Franklin Gothic Medium"][B]White Jeep Club Member #999[/B][/FONT][/COLOR][/CENTER]
[CENTER][COLOR="Red"][B][FONT="Franklin Gothic Medium"]FireMedic[/FONT][/B][/COLOR][/CENTER]
[CENTER][I]Si vis pacem para bellum[/I][/CENTER]
[CENTER]slinky + escalator = everlasting fun[/CENTER]
ScJeepaholic is offline   Reply With Quote
Old 07-17-2009, 12:05 PM   #47
Matt99362
"Do you seriously have an airplane next to your Jeep?"
I read through the entire post, not because I have some experience to offer here, but because of the plane next to the Jeep. When I build my new shop, I will be building it that big. If I can't pull a plane, a Jeep and a boat side by side through it, it ain't big enough... :-)
Matt99362 is offline   Reply With Quote
Old 07-17-2009, 01:06 PM   #48
marylandjeeper
Originally Posted by speeddemon651 View Post
I'm building it down in southern MD, where are you located ?
ellicott city, but i'd drive down to check this thing out.
marylandjeeper is offline   Reply With Quote
Old 07-17-2009, 03:09 PM   #49
mg2000xj
I would also drive down to check it out, but Im 15 minutes from PA. Great work, will be watching this one.
-Morgan
'00 Silverstone 2 Door XJ
Utah Jeep Crew Member #119
My Webshots
New Build
Old Build
mg2000xj is offline   Reply With Quote
Old 07-22-2009, 12:55 PM   #50
speeddemon651
2007 WK
lol, thanks. Sorry I haven't updated much. I've been tracking down a few parts. I made a plate to mount the -8 and -6 bulkheads on that mounts on top of the stock fuel sending unit(on top of the Fuel tank). I tried using sealant but just didn't feel comfortable with that holding up, so I ordered a sheet of 1/16 Abuna N gasket material, also tracked down a plug for the old oil level sensor hole in the oil pan and bought some aluminum spacers to finish mounting the intercooler and radiator. I'm also trying to switch to a newer alternator that is self exciting so when it turns , it charges. As of right now it's looking for a external resistance to activate its charging and I want to switch it to a 1 wire setup. I thought about trying to switch to a corvette style alt and power steering setup to get the alt. up high but I wont be doing any river crossing so it should be fine for now.
I'm in my shop pretty much every weekend, just let me know.
speeddemon651 is offline   Reply With Quote
Old 07-27-2009, 02:22 PM   #51
speeddemon651
2007 WK
oil pan cleaned and tapped for -4 feed and -10 return along with removed oil level sensor. Next I cleaned the alt bracket, installed a new alt. and converted it to be self exciting. So now when it spins it charges unlike the stock camaro setup.
http://i70.photobucket.com/albums/i81/speeddemon651/P1010942.jpg
Old 08-03-2009, 12:37 PM   #52
472cid
awesome PLane Pics too please
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline   Reply With Quote
Old 09-08-2009, 11:14 AM   #53
speeddemon651
2007 WK
Old 09-14-2009, 09:42 AM   #54
speeddemon651
2007 WK
Updates
some updates, tired to get alot done this weekend and well really didn't.
Old 09-14-2009, 10:08 AM   #55
spyder6
Just violated my Parole
spyder6's Avatar
you MIGHT need new axles
project looks great!
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 09-14-2009, 10:11 AM   #56
jmasin
Looks awesome! Gotta love the LS1, awesome freakin' engine!
Just curious, what oil pan is that and what do the baffles look like? LS1s are famous for oil starvation in fast corners (in cars) when all the oil is sent to one side of the pan... so I worry a little on the trail if you are at high angles, you have essentially the same issue (albeit at significantly reduced RPM). I'm not trying to be a jerk, but just something to check out and maybe plan for. For the track I ALWAYS ran 1QT overfill for this reason (this is a very common well known LS1 "feature", at least with the vette oil pan)
'03 Sport, Patriot Blue
'04 C5 Corvette
jmasin is offline   Reply With Quote
Old 09-14-2009, 10:38 AM   #57
speeddemon651
2007 WK
I've got a set of full width dana 60's sitting in the corner, they just need to be cut down, but for now the stockers will do, not planning on launching it. But it will for sure be a issue down the road. It has the 98 camaro oil pan so I'll have to check into it more but, if it's a problem I have plenty of room to fit pretty much any LS style pan in its place.
Old 09-14-2009, 11:50 AM   #58
spyder6
spyder6's Avatar
are you only using one bank of cylinders to run the turbo? seems like that might cause problems ( i know nothing about forced induction)
USAF
Blue Crush Build
Really?
Old 09-14-2009, 01:20 PM   #59
c0ncEpT
1995 XJ Cherokee
No he has a crossover pipe coming from the drivers side. Thus the log manifold he made.
c0ncEpT is offline   Reply With Quote
Old 09-15-2009, 11:01 PM   #60
speeddemon651
2007 WK
wrapped and painted the driver side manifold tonight.
Glock Forum
