#31 | |
edit. nvm video was a non turbo
"How can they tie it to the frame? Cherokees do not have a frame. Idiot." |
#32 |
Nice, I have alot of LS1 experience. The one in my 98' camaro is a 408 stroker with a tone of nitrous. I didnt read every post, but there was some questions about the fuel pump. a 255 fuel pump and ford svo 42 fuel injectors are a must. If you have that your fuel system will support pretty much anything. Also look into investing in LS1 edit software unless you know a local dyno tuner that has it.
2008 Wrangler Unlimited-X 4x4 Steel Blue Metallic |
#33 |
Updates....
So far I have mounted my fuel tank bulkheads along with a plate I designed to with with the stock unit, need a few more nylon washers and to seal it all up. Next I've went through my complete wiring harness and made it a stand alone harness and ready to wire up in the jeep and rewrap, third I'm making some progress on my turbo manifold and cross over tube, need to modify and weld some more. should have measured twice before hand. I'm going to have to cut and reweld the upper portion of the turbo manifold to clear the shock tower
#34 |
Look'n good man.
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s |
#35 |
That in one cleaaaaaaaaaaaaaan jeep
Signatures are for attention whores. Oh the irony. |
#36 | |
Straight Up Fool!
You sir are insane! Nice work!
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
#37 |
are you giong to cut the inside of the fenders?
1998 Gun Metal Blue TJ LS1 powered TJ RIP- Brother rolled it. 2003 RCSB Silverado MP70 Turbo AKA Lightning killer http://www.jeepforum.com/forum/f7/my-v8-swap-blog-updates-365293/ |
#38 |
As little as possible, looking to mount the turbo up high where i have plenty of room.
#39 |
#40 |
Man, that's gonna be a beast when it's done... I'll be watching this thread.
'06 Wrangler Unlimited |
#41 |
watching this thread. awesome job so far
#42 |
I have a friend with a 67 bronco that he is doing the same thing with a suburban ls1. He is coming down to the hydrolic clutch, and is having problems. Any with yours?
#43 |
I'm not sure what you mean to say ? I'm running a 4l60e automatic transmission.
#44 |
i'd love to come check this out sometime. shop open for visits? i'll bribe you with beer too.
#45 |
I'm building it down in southern MD, where are you located ?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
