Quantcast Ls1 Single turbo TJ - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Ls1 Single turbo TJ
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 07-01-2009, 02:41 PM   #16
Aero540t
1981 CJ7
Is that a T6 next to your Jeep?? One of my former bosses is building one of them right now to accompany his Stearman that he built. I'll take a ride in that!
Then a ride in the Jeep of course. NICE build. I'm loving the glossy paint on the frame and axles, very clean.
Aero540t is offline   Reply With Quote
Old 07-01-2009, 02:58 PM   #17
speeddemon651
2007 WK
Originally Posted by Kip03TJ View Post
Do you seriously have an airplane next to your Jeep? I will also be going the turbo route but I'm saving for AEM's stand alone computer to run the set up. What are you thinking of using? I'd be glad to drive down and give you a hand sometime when you start fabbing things up.
The plane is a 41 ww2 At-6 texan, I'll just be getting the pcm flashed programmed, with a mail order type program to get it on the road and to a local tuning shop then had a custom tune made on the dyno. I'll most likely be using HPtuners to flash my pcm.
speeddemon651 is offline   Reply With Quote
Old 07-01-2009, 03:04 PM   #18
Nefarious
Your frame and axle coating looks great. Good luck with the build. I've got an LS1 powered GTO and couldn't imagine it with a turbo.
2005 Rubicon Unlimited Sahara Edition 605/1000
2001 WJ Limited - Sold
www.rubiconsahara.com
Nefarious is offline   Reply With Quote
Old 07-01-2009, 03:05 PM   #19
Unlimited04
Unlimited04's Avatar
nice build! keep up the good work and don't worry about these turbo haters. they just don't know what they're talking about a turbo can be run off-road and will work just fine in water crossings if its setup correctly.
more pics of the texan please!! radial piston engines are freakin' awesome!
Unlimited04 is offline   Reply With Quote
Old 07-01-2009, 03:19 PM   #20
speeddemon651
2007 WK
The frame was really starting to get in bad shape in the rear, the front half was just fine due to the major about of oil the previous Ford 5.0 and c6 tranny leaked regularly spraying every where. I sand blasted for about a day or two. Next I thinned gallon of tractor paint to make two gallons and put it on super heavy, I hate rust..... About the Ls1 you say its alot of power untill you get used to it and then you want more. I'm looking to make 500 - 525 at the crank easy, I'll be adding a Spek water/meth kit also
Old 07-01-2009, 04:58 PM   #21
DH19922010
Wow. I wish i had the knowledge and ability to accomplish something like this The money to do it would also be helpful Good luck on the build
DH19922010 is offline   Reply With Quote
Old 07-01-2009, 05:05 PM   #22
Imped
TITS
Imped's Avatar
What are the rest of the specs of the jeep? Axles? Gearing? T-case? Etc.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 07-01-2009, 08:13 PM   #23
speeddemon651
2007 WK
Stock dana 30, 35, 4:10 years , Dana 60's are sitting in the rack ready to go for down the road.
Rebuilt NP 231, Chevy planetary, heavy duty chain kit, cv kit, ETC......
Old 07-01-2009, 08:37 PM   #24
K&VRubicon
2010 JK Wrangler
I like were your head is at
2003 Rubicon, oba - Gone but not forgotten
2010 Mango Tango Unlimited
"Time is an illusion, Lunchtime doubly so." - Ford Prefect
K&VRubicon is offline   Reply With Quote
Old 07-01-2009, 08:52 PM   #25
472cid
Plane Pics!!!!!!!!
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline   Reply With Quote
Old 07-01-2009, 08:53 PM   #26
Doctor7474
On the 4L60E the weak point is the sunshell gear, seen more then I can count let go destroying the trans. I would contact Aamco and find out who there parts supplier is for rebuild kits, they replaced it with a billet type sunshell, not saying have Aamco rebuild it but there parts supplier is a good one, and GM will still try to sell you the horrible stamped gear in there kits.
And the myth about turbo's being bad when water gets on them like the OP said they come on many off road/wet applications so it is definately a myth. Anyway if that were the case Cat converters would be trashed every time they it rained outside, it's the hottest part of the vehicle a chemical oven with some very brittle internals. So yea I wouldn't worry about the turbo.
Doctor7474 is offline   Reply With Quote
Old 07-01-2009, 09:52 PM   #27
Boodyrider
And if you're on EFA or ls1tech, you already know about the guy near Aberdeen who does the 4L60e builds using 4L65 parts, like the sunshell.
Sounds like you did your research and have some LS1 experience. The factory LS1 PCM should do fine running that, but I predict you'll want more fuel pump depending on how much boost you'll see. It's common to need a dual 255 pump setup for LS1s making more than 500 on a turbo. Invest in a wideband O2 for permanant install to help tune and keep A/F surviveable.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Old 07-02-2009, 12:32 AM   #28
speeddemon651
2007 WK
I work for Propartsllc, Aka Spek Gauges so I know a thing or two about setting up turbo cars/ truck/ Suv's and Tuning. Walbro 255 is pretty solid untill around 525 or so depending on the injectors/Duty %/boost psi/ etc etc. Already have the Y plumed for the second pump down the road. I'm not worried about the tranny, blow it up and I'll go to a 4l80e off ebay pretty cheap. Already have the Lc-1 wired up, I'll post pics of the Trubo Hott side shortly.
Does anyone know of any LS powered Wranglers that are turbo in the World???? I have really been looking but cant find anything, If so I want to be the first !!
Old 07-02-2009, 01:47 AM   #29
Bottledbird68
In for updates!!!
I keep blowing off oil changes in the 4.0 in ours so I have a reason to swap in an LQ4 lol.
I was seriously considering adding a single turbo too. Can't wait to see how yours turns out
96 ZJ 3.5" pro-comp on 33" MT/R's with black steelies
The family wheeling wagon. (Broken, but about to be better ;D) Edit, gave up and sold it lol. Concentrating on the TJ now :D
99 TJ Sport Her ride. 2" BB w/ 32" bfg MT's on black steelies
Bottledbird68 is offline   Reply With Quote
Old 07-03-2009, 01:22 PM   #30
TXjeepTJ
i wanted to do this but have no money left! BLAH!!!! you better get a video of it spooling!
you suck!!!! (in a friendly jealous way) lol
looking at mine, i dont know if there would be any room for a turbo in the engine bay. Can't wait to see how you configure everything!
1998 Gun Metal Blue TJ
LS1 powered TJ RIP- Brother rolled it.
2003 RCSB Silverado MP70 Turbo AKA Lightning killer
http://www.jeepforum.com/forum/f7/my-v8-swap-blog-updates-365293/
TXjeepTJ is offline   Reply With Quote
Glock Forum
