Quantcast Lowrider Jeep or need new springs? 56k Gonna hate me - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Lowrider Jeep or need new springs? 56k Gonna hate me
Old 01-27-2006, 07:10 PM   #1
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
Well, i've had my jeep for about 5 months (6k miles). Tis my first jeep and i've honestly never ridden in another wrangler. So i assumed a roiugh ride was just "a jeep thing". Well last night, while tightening up my rear sway bar i noticed that my bumpstops were pretty much hovering above my perches. I'm pretty certain that this isn't normal.
So, is this a sign to upgrade? I dont have alot of money, and would like to do this right, yet cheap. There's no way i can afford Long Arms and i'm going to have to do what i can with the stock arms. Currently i am running 32" 11.5" Tires. I get nearly no rubbing when connected, but rub like a masseuse when disconnected. I'm also interested in getting a 1" body lift, 1" motor lift, and lifting my transfer case with a replacement homemade tummy tuck skid that just goes from frame to frame. Just to get my ground clearanges a little better. But that can wait.
So to get 2-3.5 inches outta this thing, what needs to be done? I know i'll need new springs, prolly a trasfercase drop, an alignment... what else?
Here's a summary of my plans with the lower half of the jeep.
NOW:
New springs (2-3.5" lift)
Adventually:
1" Body lift
1" Motor Lift
Home Made Tummy Tuck
SYE kit
What am i going to need to do the achieve my first goal? What are my necessities? Throw me some brands, idea, opinions, whatever you got.
Here's some pictures of what's going on atm.
Front view of rear drivers side.
Rear view of same spring.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Old 01-27-2006, 07:15 PM   #2
18to80DDC
Built Not Bought
18to80DDC's Avatar
no there is definitly something wrong with that, maybe someone put bump stop extenders with a spring lift and then put the stock springs back in before selling it?
The bump stops look like they are way too far down for stock.
2" you can get with a Budget boost, 3.5 you will have to go with a full lift, and then you can start to kiss your cash goodbye.
from what you are saying I would definitely say budget boost.
2001 4.0L Wrangler Sport - 3.5" lift on 33's
1973 CJ5 360 - 4" lift on 35's
1982 CJ7 360 - 2" lift on 32's
1971 Series III E-type Jaguar V12 - no lift...
18to80DDC is offline   Reply With Quote
Old 01-27-2006, 07:17 PM   #3
Varnish
Moab dreamin'
Varnish's Avatar
Passenger rear the same? Like 18to80DDC suggested, is there spacers above the bumpstop cups?
Varnish is offline   Reply With Quote
Old 01-27-2006, 07:18 PM   #4
RnEmOvr
Never Forget
RnEmOvr's Avatar
for a 3" lift you prob wont need a SYE but might, alot of ppl like Old Man Emu (OME) good, cheap kits, most kits are complete with springs and shocks, bump stop extensions, and TC drop,
you have full pics of jeep? so we can see wheel gap,
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 01-27-2006, 07:26 PM   #5
Divinitous
Divinitous's Avatar
There was definately something added into this jeep. Now that i think of it, if the rear springs were that bad, the *** would be dragging along the ground. But there is no rake to the jeep. So, how do in take this crap out? I guess i'm going to need some spring compressors.
-Ryan
Old 01-27-2006, 07:33 PM   #6
ChristopherJ
ChristopherJ's Avatar
No spring compressors needed. Just get the frame as high as you can on jack stands and jack up one side of the axle. The spring on the other side should fall right out. You then insert the new spring, and voila. Repeat for the other side.
ChristopherJ is offline   Reply With Quote
Old 01-27-2006, 07:38 PM   #7
18to80DDC
Built Not Bought
18to80DDC's Avatar
This may not work with the extended bump stops in. But they can just be ratched out, it's just a self threading bolt that holds them on. The rubbery part of the bumpstops just pull out, nothing but friction to hold them in.
Old 01-27-2006, 07:39 PM   #8
Muddeprived
Sir, PLEASE post a picture of the whole jeep. I gotta see how low this thing is. Those are stock springs and look cut to me. Maybe they were cut intentionally to rid the jeep of the rake.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote
Old 01-27-2006, 07:40 PM   #9
18to80DDC
Built Not Bought
18to80DDC's Avatar
If they were cut they would be cut on the top, since it has the normal curve on the bottom, I can't see the top from the pics though.
Old 01-27-2006, 08:08 PM   #10
Divinitous
Divinitous's Avatar
Sure, but it looks fine from the outside. I simply over reacted with calling it a low rider, heh.
-Ryan
Old 01-27-2006, 08:09 PM   #11
ChristopherJ
I would think suspension at full droop would allow the space you're needing. Especially with the sway bars disconnected. The bumpstop on mine just pulled right out.
Old 01-27-2006, 08:21 PM   #12
Divinitous
Divinitous's Avatar
Would it be easier if i were to remove the rear sway bar? I have 32" tires and no lift, so i wont get much articulation outta the rear.
-Ryan
Old 01-27-2006, 08:26 PM   #13
ChristopherJ
First you lift the jeep as high as you can by the differential with your jack. Then place the jack stands near the control arm brackets on the frame in the rear. You can lower your axle a little and take the tires off and unhook the swaybars, then lower the axle till it rests on the jack. You now have the frame up really high, and the axle drooped down really low. Should be a peice of cake after that.
Old 01-27-2006, 08:32 PM   #14
Divinitous
Divinitous's Avatar
Hah, take the wheels off. Christ, why didnt i think about that. Wow, i feel like an ***. I even have an engineering degree!
-Ryan
Old 01-27-2006, 08:36 PM   #15
ChristopherJ
I've always heard, "Sometimes when you're running through a forest, you need to be smacked with a branch to remember there are trees there."
Glock Forum
