lowering shifter? HELP - JeepForum.com
post #1 of 6 Old 04-29-2007, 07:20 PM Thread Starter
pvjeeper
ok so my dad had a jeep right 91 and he got a 2 inch body lift and 31's and he said that him and his friend had to grind out where the shifter was and when it was all over the shifter was lower. Why does this happen and will I have to do this to my 97 wrangler if i get a suspension lift? appreciate the HELP
pvjeeper is offline
post #2 of 6 Old 04-29-2007, 07:28 PM
RLD831
RLD831's Avatar
The transmission is bolted to the frame of the Jeep. The body lift raises the body off of the frame. The shifter stays in the same spot and the tub of the Jeep rises around it.
RLD831 is offline
post #3 of 6 Old 04-29-2007, 07:30 PM Thread Starter
pvjeeper
so i dont have to do all the stuff if i get a suspension? would i have to do anything besides just the lift in a suspension lift, with the body or frame or anything?
pvjeeper is offline
post #4 of 6 Old 04-29-2007, 07:40 PM
RLD831
RLD831's Avatar
If you only lift the suspension, you will not have problems with the shifter. I have a 1" body lift and my shifter dropped, but it feels better where it is now.
RLD831 is offline
post #5 of 6 Old 04-29-2007, 08:39 PM
bclevenger
If you go with a 4" suspension you have to lower the transfer case with supplied spacers....this makes the shifter hit...so you have to heat and bend the shifter or just put in a B&M short shifter.....a MUCH better alternative and awesome shift feel, short throws, tight and firm(just the way I lik'em) Brian
bclevenger is offline
post #6 of 6 Old 04-29-2007, 10:01 PM
RLD831
RLD831's Avatar
You don't need to adjust anything with the t-case when you lift. All he needs is a SYE.
RLD831 is offline
After lowering t-case, shifter will not stay in reverse. yj721 YJ Wrangler Technical Forum 3 08-29-2008 01:55 PM
Column Shifter to Floor Shifter covejeepsxj YJ Wrangler Technical Forum 8 04-03-2008 04:28 PM
column shifter to floor shifter conversion jeepwrnglr92 YJ Wrangler Technical Forum 3 07-03-2007 12:51 PM
Cherokee shifter acting as a Short throw shifter?? skyjacked94xj TJ Wrangler Technical Forum 7 02-03-2007 01:42 PM
Lowering LJ top. keithert TJ Wrangler Technical Forum 9 07-07-2006 09:12 AM
