Lower And Upper Control Arm Brackets - JeepForum.com
post #1 of 4 Old 12-09-2007, 12:10 PM Thread Starter
95cuin
I Have Just Purchased A 97 Sahara That Was Involved In A Accident. I Have Noticed The Brackets That Hold The Upper And Lower Control Arms Are Welded To The Axle Tubes Have Been Welded And Heated On. Is There Replacement Brackets That Can Be Welded On Or Should I Be Shopping For A New Axle Housing? These Brackets Look Light Duty At Best. Thanks In Advance
95cuin is offline
post #2 of 4 Old 12-09-2007, 12:27 PM
ILLgreenjeep
do you have any pictures? it would help to see if you need new ones or not. There are plenty of aftermarket brackets that you can purchase most major dealers will have some.
http://www.polyperformance.com/shop/home.php?cat=41
http://www.extremegearoffroad.com/st...cat=281&page=1
4inch supsension 1.25BL 1MML, 4.88s, 35 MT MTZ, LOD front bumer rear tire carrier, AtoZrockerguards, SYE+CVdriveshaft, I-6, Durango steering box, IPF headlamps-fatboy bulbs, and in the spring custom long arm suspension (copying claytons arms and modifying brackets)
ILLgreenjeep is offline
post #3 of 4 Old 12-09-2007, 02:27 PM Thread Starter
95cuin
I Will Get It Jacked Up And Get Some Shots Of It. I Know It Does It Looks Like One Of Them Was Broke In Half And They Welded It Back Together.
95cuin is offline
post #4 of 4 Old 12-10-2007, 06:59 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Here's some more options for axle brackets:
Currie
Rubicon Express
Teraflex
Blue Torch Fabworks
Clayton's
Mad4wd
Teraflex
The stock ones are weak. Most replacements that you can buy are 3/16" or 1/4" and are much stronger.
Wheelin98TJ is offline
dana 30 lower control arm brackets 2000jeeper TJ Wrangler Technical Forum 5 08-01-2009 09:05 PM
8.8 rear upper control arm brackets jeepnurse TJ Wrangler Technical Forum 3 05-13-2009 02:48 PM
Lower Control Arm Drop Brackets bfaneros TJ Wrangler Technical Forum 34 12-22-2008 07:21 AM
Front lower control arm brackets ce7vin TJ Wrangler Technical Forum 6 06-08-2008 07:09 PM
Lower Control Arm Brackets Issues fisher836 TJ Wrangler Technical Forum 3 03-24-2008 05:03 AM
