Lower radiator hose leaking - JeepForum.com
post #1 of 17 Old 10-03-2010, 03:23 PM Thread Starter
mightydog78
I recently had my radiator replaced and keep noticing antifreeze spray on my front axle. I looked under and saw that the lower radiator hose had a trail of anitfreeze from where it connects to the engine.
Ive replaced my upper hose and that was a super easy. But for the lower radiator hose I know I'll need to drain the radiator fluid of course but there is a spring in the lower hose correct? that prevents the hose from crushing under vacuum.
I already have a lower hose to replace it but is it easy to put the spring in the new one?
Oh and is it a real pain to reconnect the lower hose to where it connects to the engine??
thanks
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #2 of 17 Old 10-03-2010, 03:33 PM
XJohnnyC
XJohnnyC's Avatar
The spring will stretch as you pull it out of the old hose. So it may be easier to remove if you cut the hose along the entire length. To install the spring into the new hose, just start pushing and rotating the spring and it should go in with no problem.
If it does get hung up, like it just did on mine, you can cut the spring in half, and insert one piece from either end of the hose. Just make sure that the ends of the spring are pointed inwards so that they don't get snagged inside the hose.
I find that the lower hose is easier to install from the bottom, laying on your back.
XJohnnyC is offline
post #3 of 17 Old 10-03-2010, 03:48 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
A new hose is not going to have the spring!Older hoses did, but not the newer types!Just buy a new lower hose an install...piece of cake!
GOLENJEEPTJ is offline
post #4 of 17 Old 10-03-2010, 04:20 PM
cj847
There is about a 90% chance that your hose is not leaking and that it is actually your water pump weep hole leaking onto the hose. So check that out first. It's real easy to replace the lower hose while replacing the pump....
97 TJ Sport OPJ project (other peoples junk) I can't remember the last time I bought a new part.
cj847 is offline
post #5 of 17 Old 10-03-2010, 06:40 PM Thread Starter
mightydog78
whats the best way to check if its my water pump weep hole and not a bad lower hose connection?
wait the lower hose it connected to the water pump correct? sorry im still learning my engine parts
2013 JKU Sahara
Mechanical Engineer
post #6 of 17 Old 10-03-2010, 06:43 PM
pile_alcalineNJ
well being that your radiator is a pressurized system, the easiest way to check it is while it is running and under pressure. also, cj847 is probably right. its more then likely your water pump. its all easy work though. i did mine in my driveway with a friend in about 5 hours.that was with removing the radiator and fan, cleaning out the radiator and flushing the whole system.
Where did i put my doors?
pile_alcalineNJ is offline
post #7 of 17 Old 10-03-2010, 06:46 PM Thread Starter
mightydog78
dang, i really dont have the tools right now to remove the radiator again, so should I just replace the water pump?
do water pumps go out eventually anyways?
2013 JKU Sahara
Mechanical Engineer
post #8 of 17 Old 10-03-2010, 07:11 PM
pile_alcalineNJ
yes they do go, but theres no saying that it is.
the only tools you need are a set of metric and standard sockets.
and just check it when your engines running. you'll see where its coming from.
post #9 of 17 Old 10-03-2010, 08:51 PM Thread Starter
mightydog78
with the engine running will i see it squirting out?
2013 JKU Sahara
Mechanical Engineer
post #10 of 17 Old 10-04-2010, 06:54 AM
cj847
To check the week hole, look from under the jeep. Shine a flashlight on the water pump. You will see a small hole in the bottom of the casting. If it is all gunkie or has green water coming out, it means your seal is going out and you have to replace the pump.
cj847 is offline
post #11 of 17 Old 10-04-2010, 07:17 AM
wlmonk
Not trying to be a smarta** here but have you checked to make sure the hose clamp is tight enough?
wlmonk is offline
post #12 of 17 Old 10-04-2010, 08:24 AM Thread Starter
mightydog78
i plan on checking that too, i think the stock clamps are pieces of junk
2013 JKU Sahara
Mechanical Engineer
post #13 of 17 Old 10-04-2010, 11:26 AM
bige2533
Watch out for issues with which year hose you have. There seem to be problems with some part numbers for 99 and 2000's. When you go to replace the hose watch out how the new one fits.
bige2533 is offline
post #14 of 17 Old 10-07-2010, 11:59 PM Thread Starter
mightydog78
well dang im pretty sure it is the water pump now. there is now always a pool of coolant if i let me jeep sit in the parking lot for a while.
i think ill try and tackle this project myself and go get one at advance auto parts. ive look around for water pump write up's
is this a hard install and are advance auto parts' water pumps decent?
2013 JKU Sahara
Mechanical Engineer
post #15 of 17 Old 10-08-2010, 12:13 AM
garybattles
I would buy a factory water pump, or an equivelent OEM after market one to avoid problems in the future. Jerry pointed out in another thread that there is a definite difference in the cheap ones. I would not go with a rebuilt unit. Just my opinion. Not a hard job. If you're replacing the w.p., might as well flush the system, change heater hoses, replace thermastat.
Napa has a decent OEM replacement. Mine went out on a Saturday, the Jeep parts place wasn't open, and I needed the Jeep to drive to work on Monday. Purchased theirs and when comparing it to the original I took out, it seemed pretty comparable. Would still go with factory if I had the chance.
gmb08
garybattles is offline
Lower Radiator Hose samger2 TJ Wrangler Technical Forum 25 07-25-2016 04:18 AM
Lower Radiator hose is not hot brinoff YJ Wrangler Technical Forum 4 08-09-2009 09:56 AM
lower radiator hose nj95yj YJ Wrangler Technical Forum 4 04-08-2009 10:11 AM
Lower radiator hose leaking WranglerRush YJ Wrangler Technical Forum 4 02-10-2009 05:36 PM
Lower radiator hose voigtrobert TJ Wrangler Technical Forum 8 11-25-2005 08:00 PM
