lower lift, bigger tires, longer bumpstops? - JeepForum.com
post #1 of 8 Old 04-19-2006, 10:39 AM Thread Starter
BNovak
BNovak's Avatar
Ok so here's what I was thinking this morning and wanted to know what everyone else thinks. Maybe I'm crazy though.....
I know the measurement points are lousy, but it at least gives you an idea -
right now I'm running 33's (measure to about 31.5) and have about 12" between the top of the tires and the BOTTOM of my fender flares (the lowest point.)
I'm thinking of going to 35's or 36's which still leaves me with quite a bit of fender gap. I'm wondering if I can drop my springs an inch (of the BL) and just increase the bumpstops to keep the wheels from rubbing.
So, the question is, if I limit the UPTRAVEL to about 5 or 6" is this going to hurt any traction?
I'm just getting sick of this thing being so damned tall but I want the taller tires.
Sorry - I know, long winded today.
Thanks
-BN
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #2 of 8 Old 04-19-2006, 11:16 AM
frankiefire702
I think you'll be fine. I know quite a few guys around here (myself included) that run 35's with 4" suspension and 1" body.
06 tj locked on 36's.
frankiefire702 is offline
post #3 of 8 Old 04-19-2006, 11:33 AM
jayr
jayr's Avatar
A veteran Jeeper in one of our clubs has a Rubi with 2" coil spacers and a 2" BL and runs 35s no problem. Youd swear they were 33s cause the Jeep sits lower than most with 35s.
jayr is offline
post #4 of 8 Old 04-19-2006, 11:57 AM
frankiefire702
AHere's a shot fully flexed in the front on the bumpstop.
post #5 of 8 Old 04-19-2006, 12:22 PM
Spiderman
Spiderman's Avatar
If the bumpstops are too long, you'll bang your axle going over bumps ect. It's not fun, I've been there.
2001 Sport 4.0L, 5 Speed, Patriot Blue
33 X 12.50 BFG A/T's with A/R Atlas 15 X 8 wheels
4.56's, RE 3.5" lift, Currie 1" BL, M.O.R.E. 1" MML
Aussie D30 Locker, & other crap
Spiderman is offline
post #6 of 8 Old 04-20-2006, 10:16 AM Thread Starter
BNovak
BNovak's Avatar
even dropping the springs an inch (or getting rid of the BL) I figure I'll still have at least 8 inches of travel between the bumpstops. (I've hammered bumpstops before, it hurts)
I'll try and snap a picture tonite - my rig looks retarded with the enormous fender gap & 33's. Maybe I'll just run 36's.
-BN
BNovak is offline
post #7 of 8 Old 04-20-2006, 10:19 AM
frankiefire702
I'd remove the bl before lowering the springs.
post #8 of 8 Old 04-20-2006, 10:49 AM
Iceman_RNR
if he's complaining about being too tall, it'll help with the COG to drop the springs down a bit, rather than removing the BL ...
Low(er) COG = GOOD
'84 CJ7, '96 CTD, '00 TJ
Iceman_RNR is offline
Need longer bumpstops, and shock travel? Scotch740 TJ Wrangler Technical Forum 7 09-11-2008 02:55 PM
Bigger Tires - Lift tennisgopster JK Wrangler Technical Forum 3 04-01-2008 04:36 PM
who has had a lift w/bigger tires and no esp problems? rondawg JK Wrangler Technical Forum 8 05-07-2007 10:47 AM
bigger tires before lift doubleA TJ Wrangler Technical Forum 12 03-01-2005 03:22 PM
Lift + Bigger Tires - Really Need Advice steve3911 TJ Wrangler Technical Forum 10 09-10-2004 09:49 PM
