Lower control arm placement - JeepForum.com
post #1 of 8 Old 07-16-2013, 11:48 PM Thread Starter
dbender
OK,,,, as you guys know im trying to get this lift kit installed. The jeep had a lift on it. It had pro comp lower control arms. I am installing the savvey/currie 4" lift. The directions say that the control arm come pre set. Any way I believe they drilled another hole in the lower control arm bracket for the old lift kit. which one should I use with this new kit. Are the holes to the rear the original holes or did these jeeps have two holes from the factory???
THX
Dave
dbender is offline
post #2 of 8 Old 07-17-2013, 04:48 AM
JEK3
JEK3's Avatar
Taking a quick glance at mine, I would say the factory hole is the one furthest from the edge (the higher one). Looks like someone tried to cheat and get a little more lift/stretch/articulation/whatever. You might want to figure out how to get a weld repair on that second hole, as it may be weakening the mount.
JEK3 is offline
post #3 of 8 Old 07-17-2013, 07:29 AM Thread Starter
dbender
Roger. I see what you mean. The currie kit requires drilling out a larger hole and the tolerance will be even less then. Between the two holes.
THX
Dave
dbender is offline
post #4 of 8 Old 07-17-2013, 08:52 AM
Hosejockey61
I measured mine right now (with the CA's off) and it's right about 1 3/4" depending on where you measure from...but that should be close enough for determining which hole to use.
Hosejockey61 is offline
post #5 of 8 Old 07-17-2013, 08:56 AM
Imped
Imped's Avatar
THX
Dave
The JJ's use a 9/16" bolt, which fits fine through the factory hole.
OlllllllO
IndyORV
Imped is offline
post #6 of 8 Old 07-17-2013, 09:17 AM
cjheap
rear hole is factory. I just looked ant mine that has the arms off at the moment.
if you are worried about strength, you can weld a big washer on the bracket to reinforce the correct hole.
By rear, I mean the hole furthest from the edge and closest to the frame
cjheap is offline
post #7 of 8 Old 07-17-2013, 09:24 AM
jeepinhokie
weld washers for reference... http://www.ruffstuffspecialties.com/...Category_Code=
HOKIES UNITED!
jeepinhokie is offline
post #8 of 8 Old 07-17-2013, 10:31 PM Thread Starter
dbender
Ok... good stuff...Thanks guys
Dave
dbender is offline
