Lower Control Arm Drop Brackets - JeepForum.com
post #1 of 35 Old 12-16-2008, 12:04 PM Thread Starter
bfaneros
I Was Wanting To Know Where I Could Find Some Lower Control Arm Drop Brackets? I Have Seen Them On A Jeep Before And Haven't Been Able To Find Any For Sale Anywhere ... Can Anyone Help Me ? Thanks
bfaneros is offline
post #2 of 35 Old 12-16-2008, 12:47 PM
CHEROKEE97
CHEROKEE97's Avatar
I think Skyjacker used them at one time as part of a full lift. As for as I know they are only made for XJs now.
2001 silver Jeep TJ sport 4.0 5spd. 33X12.50X17 Mickey Thompson MTZs. ARB locked high pinion 30, Detroit locked 33 spline super 44 rear. 4:56 gears, 2" RC lift with JKS Acos spacer in the front , 1" body lift, RE adjustable control arms both ends, Procomp MX6 shocks, JKS track bars, stock bumpstops, Currie steering, Antirock swaybar, 4.0 5spd with Hurst shifter, 1" motormount lift, Highrock front bumper with Warn 8000lb winch, Procomp rear bumper
1997 Black Cherokee. RE 4.5" lift 33X12.50X17 Mickey Thompson MTZs. ARB locked 30 front. Detroit locked 8.25 rear. 8000lb Warn. 4.0 auto. 4:56 gears. JKS ACOS spacers, Currie steering, Currie anti rock sway bar, Raised & trimed fender flares, JKS stops, 231 Transfer case with H&T and RE drive shaft. RE control arm drop brackets, Warn sliders etc etc
(FLOPPED AND JUNKED FOR A TJ R.I.P.)
CHEROKEE97 is offline
post #3 of 35 Old 12-16-2008, 12:49 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Welcome and why?
TheBoogieman is offline
post #4 of 35 Old 12-16-2008, 12:57 PM
Bob416
i kno some older XJs had an issue with the lower control arms hittin the axle when they were lifted, thats the only reason i can think of for a bracket like this
Bob416 is offline
post #5 of 35 Old 12-16-2008, 01:25 PM
Varnish
Varnish's Avatar
The **** Cepek lift kit used them, a quick google came up with this which seems to deal them now:
http://www.extremesuspensions.com/st...cat=293&page=1
Maybe contact them to see if you can get them separately.
'98 TJ, '06 LJ, '88 YJ
Varnish is offline
post #6 of 35 Old 12-17-2008, 06:53 AM Thread Starter
bfaneros
Thanks ... Yea My Lower Control Arms Have A Little Much Of An Angle Issue And I Am Having A Clearance Issue With The Control Arm Hitting The Axle. Soon I Will Have A Long Arm Kit For The Front But Not Soon Enough. I Was Looking For A Quick Fix For Now. 10" Of Suspension Lift Is A Lil Much For A Short Arm Setup
bfaneros is offline
post #7 of 35 Old 12-17-2008, 07:41 AM
hscrugby
What?
1. 10" of lift? WHAT size tires are you running?
2. 10" of lift?
3. 10" of lift and you haven't completely redesigned the suspension and replaced the axles?
4. how does the steering work?
hscrugby is offline
post #8 of 35 Old 12-17-2008, 08:10 AM
bairy
PICTURES! I gotta see the control arm angle.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #9 of 35 Old 12-17-2008, 08:16 AM
TheBoogieman
Disturbed
Originally Posted by hscrugby View Post
What?
2. 10" of lift?
Check out his profile gallery for pics of it.
post #10 of 35 Old 12-17-2008, 11:45 AM
timritchieblue
39.5 irocs & a DANA 35?????? and i thought i was pushing it with 33's. heres the link http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
FOR SALE:SOLD
2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I
timritchieblue is offline
post #11 of 35 Old 12-17-2008, 11:50 AM
TheBoogieman
Disturbed
Don't forget that WEAK D35 is only on a 10" lift. No LCOG here.
The guys in that link are good people.
post #12 of 35 Old 12-17-2008, 11:51 AM
97casteeltj
97casteeltj's Avatar
now all he needs is a 3"BL to finish it off!!
needing a new rig....
97casteeltj is offline
post #13 of 35 Old 12-17-2008, 11:54 AM
LJameson
10" on short arms?!?! That thing must ride like poop! And please tell me that D35 at least has a super 35 kit. I can't imagine what'd happen when you punch it in low range
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #14 of 35 Old 12-17-2008, 11:55 AM
TheBoogieman
Disturbed
That would look so cool.
post #15 of 35 Old 12-17-2008, 11:56 AM
timritchieblue
mall crawler?
FOR SALE:SOLD
Control Arm Drop Brackets? wideopen_mx TJ Wrangler Technical Forum 14 10-18-2009 03:19 PM
dana 30 lower control arm brackets 2000jeeper TJ Wrangler Technical Forum 5 08-01-2009 09:05 PM
Front lower control arm brackets ce7vin TJ Wrangler Technical Forum 6 06-08-2008 07:09 PM
Lower Control Arm Brackets Issues fisher836 TJ Wrangler Technical Forum 3 03-24-2008 05:03 AM
Lower And Upper Control Arm Brackets 95cuin TJ Wrangler Technical Forum 3 12-10-2007 06:59 AM
