Lower Control Arm Brackets Issues - JeepForum.com
post #1 of 4 Old 03-23-2008, 12:50 PM Thread Starter
fisher836
fisher836's Avatar
I'm just curious if anyone else has issues with the holes that go through the lower control arms brackets where the lower control arms attach to the frame? Mine are stretched out and getting worst. I know what my solution to the problem is going to be.. grade 8 washers welded over the hole. I just never hear of anyone else having this problem???
Definition of Rubicon:
A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment.
fisher836 is offline
post #2 of 4 Old 03-23-2008, 03:23 PM
spinner
My '97 had the problem with the rears when I got it. It had aftermarket contol arms that had elongated where the bushings fit in, allowing movement. My best guess is that the hammering from the slop causes the problem. I would check the control arms and bushings too. My fix was the same as you suggest except I welded in the elongated part of the holes, redrilled, then welded the washers on.
'97 TJ Sport
4.0 Auto
4" lift. 33" TSL's
'74 CJ5 project
spinner is offline
post #3 of 4 Old 03-23-2008, 05:04 PM
Crunch
You could just cut off your CA brackets and put on long arms.....
New one-2000 XJ sport- Now has 3.5" lift, Hp 30/8.25 w/4.10's, V8 Zj steering
Totaled 3/18/10-'99 Black 2 door XJ DD, 3.5+" bastard lift.
SOLD-'98 TJ 4 banger 5 speed, 4.88's, Hp 30 ARB'd, S35 w/Detroit and truss, RK LA's, Kilby skids and LOTS of other junk. Should have kept it!
Traded for my XJ - '98 ZJ was pretty and built at one time- Hp30, 8.8 and 5" lift and other stuff.
Crunch is offline
post #4 of 4 Old 03-24-2008, 05:03 AM Thread Starter
fisher836
fisher836's Avatar
If only I had the cash my friend.
pic's of front lower control arm brackets clearanced timritchieblue TJ Wrangler Technical Forum 0 12-16-2009 07:29 AM
dana 30 lower control arm brackets 2000jeeper TJ Wrangler Technical Forum 5 08-01-2009 09:05 PM
Lower Control Arm Drop Brackets bfaneros TJ Wrangler Technical Forum 34 12-22-2008 07:21 AM
Front lower control arm brackets ce7vin TJ Wrangler Technical Forum 6 06-08-2008 07:09 PM
Lower And Upper Control Arm Brackets 95cuin TJ Wrangler Technical Forum 3 12-10-2007 06:59 AM
