Lower Control Arm bolt size? Has TuffCounty lift but I believe bolts are stock size. - JeepForum.com
post #1 of 11 Old 08-12-2010, 11:01 PM Thread Starter
SolidBrass
What is the bolt size for lower control arms (rear). Would like to install Grade 8's.
SolidBrass is offline
post #2 of 11 Old 08-13-2010, 11:42 PM Thread Starter
SolidBrass
no answer? How about best (cheap) front lower control arms. I'm about to buy RC.
post #3 of 11 Old 08-14-2010, 12:25 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Boy, who did you irritate? Lower control arm bolts are 9/16's fine thread if you prefer. Stock is 14mm.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #4 of 11 Old 08-14-2010, 12:25 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I'm confused, do you want the best or the cheapest. Last I checked, they weren't the same arms.
I am Savvy
mrblaine is offline
post #5 of 11 Old 08-14-2010, 05:38 PM Thread Starter
SolidBrass
It needs to be adjustable. I would also like at least one "johnny joint" or similar.
post #6 of 11 Old 08-14-2010, 10:58 PM Thread Starter
SolidBrass
I don't see any swivel joints under $200 except rough country @ $180.
post #7 of 11 Old 08-15-2010, 06:55 AM
heymatt
Check rustysoffroad.com
heymatt is offline
post #8 of 11 Old 08-15-2010, 07:35 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Got em from Sean at Rokmen.
Rokmen Gear Up....Rok On
Certainly not the cheapest, but definitely the best
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 11 Old 08-15-2010, 05:40 PM Thread Starter
SolidBrass
You have the johnny joints on the frame side. Is that right? Don't know why but I was sure it goes the other way. Or maybe it doesn't matter.
post #10 of 11 Old 08-16-2010, 02:15 AM
Kiwi Jeeper
Rokmen instructions say them to be on the frame side. So he has done it right. I know 'cause I have the same LCAs.
'12 JK Rubicon V6 3.6L
'15 KL Trailhawk V6 3.2L
Kiwi Jeeper is offline
post #11 of 11 Old 11-09-2010, 10:00 PM Thread Starter
SolidBrass
Long delayed response but wanted to chime in.
It make a LOT of sense that the johnny goes frame side. Installing them you find that side is MUCH heavier. Keeping any extra weight on frame and not 'sprung weight' traveling with the axle. (all angles being equal) Double johnnies do seem obvious for max flex.
Lower control arm bolt size. 99TJtommy TJ Wrangler Technical Forum 8 01-27-2010 12:50 PM
lower shock bolt size default83 TJ Wrangler Technical Forum 0 12-13-2009 10:54 AM
Front Lower Control Arm Bolt Size??? JoeyOPA TJ Wrangler Technical Forum 2 04-22-2009 11:11 AM
lower control arm bolt size? freshlikefruit TJ Wrangler Technical Forum 5 02-23-2009 08:28 PM
Lower control arm bolts, what size? Muddeprived TJ Wrangler Technical Forum 4 09-06-2007 07:19 AM
