Low Speed Engine shut-off - JeepForum.com
post #1 of 5 Old 01-01-2014, 05:31 PM Thread Starter
PeteTJeep
Ok so I'm new to the Jeep community and my jeep has its share of issues. It's a 2002 with the 4.0 and auto tranny. I have the O2 sensor issue that a lot of jeep owners have but since my engine is working fine I'm not concerned with that at this point. The issue I'm having that i want to discuss today is what I believe to be an overheating issue.
What happens is that I go wheeling and am going low speed with high revs up hills after about an hour of hills when i get to the top the engine will shut off and i won't be able to start it again for about 20 minutes until the engine bay cools down.
I replaced the coil pack, still having the problem. My next thought is to put in an electric fan and louver the hood to let out the hot air.
Has anyone else had this problem? know what it might be? know how to solve the issue?
thanks
PeteTJeep is offline
post #2 of 5 Old 01-01-2014, 06:26 PM
tomsrancho
Mountain Jeeper
In the old days, it would probably be vapor lock, though the high rpm's should prevent that. What's your temp gauge read while you're doing this?
tomsrancho is offline
post #3 of 5 Old 01-01-2014, 06:31 PM Thread Starter
PeteTJeep
Reading normal at 210
post #4 of 5 Old 01-01-2014, 07:05 PM
chris142
IMO you have a bad Crank Position senser. It's kinda on top of the bell housing, drivers side. Sometimes you can get under there and tap on it, if it starts after tapping tap it again and see if it dies.
chris142 is offline
post #5 of 5 Old 01-01-2014, 07:10 PM
freeskier93
Hood louvers would help, sounds like heat soak is causing some issues. Don't get an electric fan, the mechanical fan is blowing plenty of air.
freeskier93 is online now
overheating
