Low Speed Bucking - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Low Speed Bucking
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 03-12-2005, 08:26 PM   #1
MCanavan
Low Speed Bucking
Whenever I start up my 1998 Wrangler Sport for a few hundred yards or so the Jeep bucks. It sort of like it isn't getting enough gas to keep it going. After a few minutes the Jeep is fine, could the engine be cold? What's the problem?
MCanavan is offline   Reply With Quote
Unread 03-12-2005, 08:47 PM   #2
MCanavan
Anyone????
Unread 03-13-2005, 01:04 AM   #3
davage
what happens if you let it idle a few minutes before you go anywhere? If it's a 5 speed, do you have the RPMs so low that it almost stalls?
davage is offline   Reply With Quote
Unread 03-13-2005, 02:42 AM   #4
175MM BULLDOG
175MM BULLDOG's Avatar
I would suggest letting it warm up a while. An engine with those miles requires more time for the oil to flow to all the necessary places to decrease friction. The warm up also thins the oil so that it flows faster. Sludge can also contribute to poor flow. You may want to try synthetic.
175MM BULLDOG is offline   Reply With Quote
Unread 03-13-2005, 06:15 AM   #5
MCanavan
OK Thanks.
Unread 03-13-2005, 06:42 AM   #6
H2_RECOVERY
1982 CJ8
check you fuel presure and replace the fuel filter first.
H2_RECOVERY is offline   Reply With Quote
Unread 03-13-2005, 04:56 PM   #7
Jim Shanks
That's easier said than done. The fuel filter is part of the fuel pump/pressure regulator/filter/anti drainback/sending unit assembly. Around $200+ and inside the tank.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Owner of IA4x4.com
Subscribe to CRAWL
Jim Shanks is offline   Reply With Quote
