Low speed bucking - JeepForum.com
post #1 of 14 Old 09-25-2011, 05:50 PM Thread Starter
Aaron0028
Low speed bucking
I have a 2000 tj 4.0 5 speed that bucks when I'm going slow. It only happens when I have decreased my speed and am going maby 5 miles per hour. Only happens when I'm in two wheel drive. It does not happen if I'm accelerating, or if i just brake, only when I stay at 5 mph or whatever. And I can only get rid of it by putting the clutch in or speeding up. It's like when I'm going 5 mph and just slightly use the gas it jumps. Not really a problem just curious. I have lockers if that matters. It doesn't happen when I don't use the gas.
Thanks
Aaron0028 is offline
post #2 of 14 Old 09-25-2011, 11:06 PM
dcope17
Do you have an SYE and DC driveshaft?
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #3 of 14 Old 09-26-2011, 07:28 AM
Jeepsr4me
What gear you in? Bigger than stock tires?
Jeepsr4me is offline
post #4 of 14 Old 09-26-2011, 08:04 PM Thread Starter
Aaron0028
yeah 1st gear 35 inch tires, no on the driveshaft
post #5 of 14 Old 09-26-2011, 08:26 PM
Jeepsr4me
Whats the gears in the axle? Cause high gears will cause the motor to buck and stall.
post #6 of 14 Old 09-26-2011, 08:35 PM Thread Starter
Aaron0028
4.88 gears, it never stalls just bucks
post #7 of 14 Old 09-26-2011, 08:40 PM
jeepnmike
jeepnmike's Avatar
Are you being easy on the gas? With 4.88s and 35s this sounds pretty normal...its geared pretty low. Mine will buck like crazy in first at very low speeds if I'm not smooth on the gas.
'95 YJ- 1.25" BL, 31" bfg's, black cragars, herc'd tub. sold
'99 TJ Sport- 35's, 8.8, 4.88s, 5" RC LA, JB SS SYE, UFC TT, HD steering
jeepnmike is offline
post #8 of 14 Old 09-26-2011, 09:13 PM Thread Starter
Aaron0028
Thanks, I'll try being easier on the gas
post #9 of 14 Old 09-26-2011, 10:07 PM
dcope17
So, you have 4.5" lift, D60 with 4.88 and 35's but no DC shaft and SYE???
With smooth throttle at about 5 MPH... you feel the pulsing of the DS cause it is not made for those angles. Do you have adjustable CAs or stock?
dcope17 is offline
post #10 of 14 Old 09-26-2011, 11:01 PM Thread Starter
Aaron0028
adjustable CAs
post #11 of 14 Old 09-26-2011, 11:16 PM
dcope17
I'm a little lost but we'll get it... A Double Cardan Drive shaft will have splines in the shaft to adjust for length during suspension movement. It requires an SYE and adjustable CAs to dial in the pinion angle.
The factory shaft will not work for the driveline angles you have with 4.5" of lift unless your D60 is a high pinion.
dcope17 is offline
post #12 of 14 Old 09-27-2011, 07:14 AM Thread Starter
Aaron0028
My d60 is high and the CAs are adjustable
post #13 of 14 Old 09-27-2011, 10:15 AM
Dogbones
what happens if you floor it in first after the bucking begins?
Dogbones is offline
post #14 of 14 Old 09-27-2011, 10:36 PM Thread Starter
Aaron0028
Reacts like a normal jeep, the bucking stops
4.0 , jeep , lockers , tj , wrangler
6 speed 2.4L owners Bucking problem Kentuckyarms TJ Wrangler Technical Forum 8 11-30-2011 02:05 PM
Quick idle speed question - Weber Carb - Speed Screw 2.5 turns in, but 0 vacuum unlucky YJ Wrangler Technical Forum 1 04-22-2011 05:30 PM
Bucking @ Hwy Speed - OD DISengaged msavard TJ Wrangler Technical Forum 5 07-28-2006 02:51 PM
Low Speed Bucking MCanavan TJ Wrangler Technical Forum 6 03-13-2005 04:56 PM
Anyone kno nething about the 4 speed auto? What year start useing? bolt into 3 speed? jeepcj7 TJ Wrangler Technical Forum 6 06-23-2004 08:33 AM
