Low oil pressure at idle 4.7 ho - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Low oil pressure at idle 4.7 ho
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread Yesterday, 07:09 PM   #1
Kevster1230
replced sender heads new oil pump no luck ... Help
Kevster1230 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:20 PM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Exactly what pressure are you getting that you believe to be too low at idle RPMs?
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:37 PM   #3
Jeepsr4me
Have you put in a manual gauge to verify the REAL pressure? Can be hooked up and just run thru the side window so you can watch or left setting under hood... or hooked up permanently 2nd pic.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 08:13 PM   #4
Imped
Imped's Avatar
4.7 in a TJ, huh?
OlllllllO
Float Test Build
IndyORV
Imped is offline   Reply With Quote Quick reply to this message
Unread Today, 06:16 AM   #5
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
4.7 minimum oil pressure 7psi idling
4.7 H.O. minimum oil pressure 4psi idling
You can't get much lower. You might be looking for the WJ forum.
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
2000' WJ Limited 4.7L-V8/D44/Quadra-Drive/31" MT's/3" lift
TheBoogieman is online now   Reply With Quote Quick reply to this message
