low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 8 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > low lift, long shocks, and DIY shock shifters... what's the advantage?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-21-2011, 10:35 PM   #106
Blktjsport
Hey mudb8 had a chance to make any mounts lately let me know thanks
2001 WJ -WIFES K&N FIPK~2.5" FLOWMASTER 40~2.5" BB~ BILSTEINS~ 255/70/18 BRIDGSTONE A/T JK'S
1999 TJ SPORT- NP242~SYE~K&N APOLLO COWL CAI~2.5" FM40 ~3.5" RE~ BILSTEIN 5100~D44~33" BFG MT~ DAVES RACK~ BUSHWACKERS~ HELLA ECODE DDM 6K HID
Blktjsport is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 07:58 AM   #107
UnsanePyro
Originally Posted by TheDragonfly View Post
Interesting, Do you have a pic of how these mount?
I'm looking for the same thing right now. I'm having a hard time picturing how it is going to work.
http://www.teraflex.biz/tj-wrangler-...tor.html#first
UnsanePyro is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 08:09 AM   #108
jeepbro's
-subscribing for later. Very interested in this
2002 tj sahara 3" lift 35" km2, AtoZ rockers, 8k warn, 4.56 gears, lock-rites front and rear
jeepbro's is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 10:02 AM   #109
mudb8
want it rite or rite now?
mudb8's Avatar
http://www.teraflex.biz/tj-wrangler-rear-upper-shock-adapter-and-relocator.html#first
If you take a look at the upper shock mount hole, you'll see it's a large square hole.
The Tera adapter fits up through the hole and bolts to the x-member using the factory shock bolts. you knock out the Bar pin, insert the correct shock bushing sleeve, bolt the adapter to the shock as if it were a BPE then stick it in place the same as you normally would when replacing rear shocks. the adapter requires a BL because they stick up an inch through the top of the x-member when installed.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 03-22-2011, 10:06 AM   #110
mudb8
mudb8's Avatar
Not any extras yet, I do have a tj with Nth degree SA suspension coming in I'll be fixing the shock problems on next week.
Unread 03-22-2011, 10:43 AM   #111
UnsanePyro
That makes some more sense now. I was thinking that the Teraflex piece had a solid bottom and had to be mounted upside down. Too early in the morning I guess
Unread 03-30-2011, 03:38 PM   #112
Sgt.Fuzz
subbed.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote Quick reply to this message
Unread 03-30-2011, 04:03 PM   #113
EricsGreen98Tj
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
Last edited by EricsGreen98Tj; 03-30-2011 at 04:42 PM.. Reason: trying to delete this post:(
EricsGreen98Tj is offline   Reply With Quote Quick reply to this message
Unread 03-30-2011, 04:40 PM   #114
EricsGreen98Tj
great ideas in here......TTMFT!
Unread 04-03-2011, 07:47 AM   #115
dragginwagon406
Figured it out lol.
dragginwagon406 is offline   Reply With Quote Quick reply to this message
Unread 04-03-2011, 08:33 PM   #116
mudb8
mudb8's Avatar
Originally Posted by dragginwagon406 View Post
Figured it out lol.
When they are parallel, at ride height, the shock bushing will not be in any kind of a bind....
Unread 04-03-2011, 08:57 PM   #117
dragginwagon406
They, meaning the shock bushing, not the shock. I mis-read into it when I saw the tape measure from the lower control arm mount.
Unread 05-10-2011, 07:41 PM   #118
kelso1337
Sorry to hear about the recent issues Mudb8. Hope all turns out well for you.
Here is what i've seen on a local jeep website.
http://www.gemini-sales.com/product....&product=13955
Would something like that work for our long travel rear shocks?
I'm thinking I am bottoming out in the rear.
Stock 2003 Jeep TJ - 'Intense Blue'
Bought the jeep in April, found JF in May...
First Mod in June.
kelso1337 is offline   Reply With Quote Quick reply to this message
Unread 05-10-2011, 07:45 PM   #119
AFjeepMan
That only extends the mount rearward, not downward or outboard like would be needed to allow for longer travel shocks...that style shock shifter is typically used to allow for the shocks to not contact the axle in applications where the axle is rotated for sye and cv driveshaft applications. Mudb8 correct me if I'm wrong.
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[URL="http://www.jeepforum.com/forum/f22/my-05-tj-build-916271/"][SIZE="3"][COLOR="Red"]My Build Thread[/COLOR][/SIZE][/URL]
[COLOR="Red"][_l_[COLOR="black"],[/COLOR][____][COLOR="Black"],[/COLOR]
l----L - [COLOR="Black"]O[/COLOR]lllllll[COLOR="Black"]O[/COLOR]-[/COLOR]
(o)_) (o)_)--)_)
[COLOR="Green"]Wife≥Jeep>GF
Relearn your priorities.[/COLOR]
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline   Reply With Quote Quick reply to this message
Unread 05-10-2011, 07:58 PM   #120
EricsGreen98Tj
^^You are correct!
