low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > low lift, long shocks, and DIY shock shifters... what's the advantage?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAMP Research Powersteps - A Morris 4x4 Center Promotion
Unread 11-04-2010, 07:03 PM   #76
UTWeezul
Upon further inspection, the lower shock mount (can't remember which side) did hit the shock body when flexing and put a tiny dent in it. Nothing that is harming the shock. I'll probably swap out the RE shock pins to a grade 8 bolt and space it out a little with a nut between the shock and the mount itself along with a washer on either side of the nut. Apart from that, a great cheap mod!
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline   Reply With Quote Quick reply to this message
Unread 11-04-2010, 07:03 PM   #77
dbbd1
dbbd1's Avatar
Originally Posted by mudb8 View Post
BTW Dave, I still haven't seen those pics of the new outboard 12" bilsteins?... I gotta get a new camera!
Oooooops!!! Will do this weekend.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2010, 11:03 PM   #78
mudb8
want it rite or rite now?
mudb8's Avatar
so after hours tonight, while I was supposed to be putting six shooter knuckles on a Toyota with the fancy new axle centering tool I made and relocating shock mounts on a TJ, I was messing around some more with bolt on relocation..... I have a couple new ideas to persue and found I get to dream up a new way to attach bilstien 5100's to the relocation brackets, previously I've only used 5125's and 5150's with my mounts.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2010, 11:09 PM   #79
bandit455
hey dave, don't know if you saw this, but it looks like clayton offroad liked your idea soo much they made a product to copy it!
http://claytonoffroad.com/product_in...products_id=88
Eagle scout jeeper #10
my build thread
The Things We Make, Make Us
bandit455 is offline   Reply With Quote Quick reply to this message
Unread 11-04-2010, 11:30 PM   #80
mudb8
mudb8's Avatar
Clayton Off Road - Lower shock conversion kit
Nope...
Clayton was doing that before I was, problem there is they mount the shocks up to high for a lower lift hieght and long shocks... Plus theres the shock body interference with the frame problem at full stuff.
Unread 11-04-2010, 11:35 PM   #81
bandit455
hmm interesting
never mind then, and fwiw my relocated stock mounts are holding up great, definitely worth the time it took
my build thread
Unread 11-04-2010, 11:37 PM   #82
mudb8
mudb8's Avatar
hmm interesting
Unread 11-05-2010, 08:47 AM   #83
dbbd1
dbbd1's Avatar
And the Claytons do not look as beefy, Mud's have have a built-in mini skid.
-John Wayne
Unread 11-05-2010, 07:14 PM   #84
AFjeepMan
Sooo Mud, my question is, how much for your version if you were willing to make and ship?
Edit: I ask because I'm really interested, but would rather give my hard earned money to you over Clayton Off Road.
2005 Wrangler TJ, 3 1/4" RC lift, Cragar Soft 8's 32" BFG Mud Terrains, Smittybilt SRC D-Ring bumpers, Smittybilt XRC8 winch, Body Armor Rockcrawler side guards
[URL="http://www.jeepforum.com/forum/f22/my-05-tj-build-916271/"][SIZE="3"][COLOR="Red"]My Build Thread[/COLOR][/SIZE][/URL]
[COLOR="Red"][_l_[COLOR="black"],[/COLOR][____][COLOR="Black"],[/COLOR]
l----L - [COLOR="Black"]O[/COLOR]lllllll[COLOR="Black"]O[/COLOR]-[/COLOR]
(o)_) (o)_)--)_)
[COLOR="Green"]Wife≥Jeep>GF
Relearn your priorities.[/COLOR]
WANTED: SYE and cv shaft...good condition and good price. for a TJ with about 5-6" of lift.
AFjeepMan is offline   Reply With Quote Quick reply to this message
Unread 11-06-2010, 02:48 PM   #85
dbbd1
dbbd1's Avatar
Thanks to Mudb8 (Dave) at Rob's Offroad, I have been outboarded. Here are the pic's...
-John Wayne
Unread 11-08-2010, 11:12 AM   #86
MikalCarbine
Been following this thread amongst others of yours mud, if you find a way to make a similar bolt on bracket I'd be one of your first customers
MikalCarbine is offline   Reply With Quote Quick reply to this message
Unread 11-08-2010, 08:37 PM   #87
mudb8
mudb8's Avatar
Well, I have, I just need the time to make it happen!
Unread 11-08-2010, 08:55 PM   #88
viperbluelx
When this is available in kit form I'm in.
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline   Reply With Quote Quick reply to this message
Unread 11-09-2010, 07:37 PM   #89
UnsanePyro
It's going to be a pretty close race between the two of us
UnsanePyro is offline   Reply With Quote Quick reply to this message
Unread 11-10-2010, 12:15 AM   #90
mudb8
mudb8's Avatar
