low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > low lift, long shocks, and DIY shock shifters... what's the advantage?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-17-2010, 10:40 PM   #46
cerebrus
Great info. $10 in scrap steel for better travel. One of the best mods I have ever seen.
cerebrus is offline   Reply With Quote Quick reply to this message
Unread 04-24-2010, 07:13 PM   #47
UTWeezul
DIY shock shifters
A few questions about this too. What part # is the Chevy shock stud/what were you saying about a grade 8 fine threaded bolt? Would the bolt be used in place of the Chevy part?
Have you had any problems with binding since the upper shock mount hasn't been moved? Just want to make sure these would be fine on a DD/weekend warrior. Thanks.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline   Reply With Quote Quick reply to this message
Unread 04-24-2010, 11:44 PM   #48
mudb8
want it rite or rite now?
mudb8's Avatar
no binding or messed up bushings, most all the ones I've done are daily drivers.
using the 5/8" bolt in place of the chevy part is just as easy as the chevy stud. sorry I can't find a pic of how it's all put togther but you can see I used a bolt with washers on each side of the shock bushing, put a nut on and snugged it up just a bit beyond hand tight to slightly compress the bushing, put it through the bracket and used an acorn lock nut to secure it to the axle bracket, you hold the bolt head till the acorn nut is snug, then put a wrench on the bushing side nut along with the acorn nut to lock and tighten the bolt stud.... dbbd1 could prolly get you a pic since this one is on his TJ.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2010, 10:03 PM   #49
jermeyg
Shock Relocation
mudb8, I fabbed up the relocation brackets that you suggested in this thread and this is where I am at. Planning on gaining close to 5" of up travel when I am done
jermeyg is offline   Reply With Quote Quick reply to this message
Unread 06-18-2010, 10:35 PM   #50
mudb8
mudb8's Avatar
Unread 06-27-2010, 02:52 AM   #51
rs4race
Originally Posted by nriver View Post
My extended pics
Not fully extended IIRC
Full Droop
I did not like this setup and moved on.
Im interested in setting up some shocks like this. I would like to get some more travel from the front, mostly down travel though. Im running the RC 2.5" lift, and actually wouldnt mind killing two birds with one stone. Get a smoother ride with some better shocks, and gain some articulation.
Any info on the cons of this setup? It seems like to me I could make a simple bracket and bolt it on with the lower control arm bolt or also weld it on.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline   Reply With Quote Quick reply to this message
Unread 06-27-2010, 03:29 AM   #52
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
i know you are supposed to mount the lower shock bolt at the same angle as the lower control arms, but i cant see why you couldnt mount that bolt parallel to the ground. what am i missing?
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 05:41 AM   #53
jeepbastard
Thanks for sharing this.
This looks like a solution from bottoming out . I am in the process of assembling a fox 2.0 shock setup wi 2 inch spring lift and 32 inch tires. This is not a ton of clearance and uptrqvel for a long shocks meant for 4 iNches of lift.
This way i an increase my range with the shocks instead of brakin everything!
O||||||X
jeepbastard is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 09:31 PM   #54
mudb8
mudb8's Avatar
it helps a bit, ultimately, a full outboard is the best way to go, especially when you're dumping a load a cash on good shocks.
Unread 08-24-2010, 09:40 PM   #55
DavidAnderson
tttt
DavidAnderson is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 09:42 PM   #56
mudb8
mudb8's Avatar
there are only cons if it's not clearanced to keep the shock body from hitting the bracket... one of the advantages is it keeps the shock bodies from hitting the frame during articulation with a 12" travel or longer shock, with about 7" down travel from ride height, you also end up with the drive shaft rubbing the auto transmissions...
heres one I did which keeps the bar pin and factory mounting, I simply cut it off and lowered it down 2".... well, there was a little more than that to the story..
it will bind the bushing in the range of movement the arms create. the shock needs to be at a 90* anlgle to the lower control arm... you can't actually get it there with the stock upper mount and just changing the lower mount. you do get some lost and useable uptravel tho.
Unread 08-24-2010, 09:51 PM   #57
mudb8
mudb8's Avatar
Rubicon Express has a shock/sway bar stud kit part # RE2051, this is the ticket if it's too much trouble for the local auto parts slacker to figure out...
RE2051 - SWAY BAR/SHOCK MOUNT STUD KIT - Rubicon Express
no binding, just rock rash.
Unread 08-24-2010, 10:01 PM   #58
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
whats the rest of the story? got more pics? i'm interested
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2010, 10:06 PM   #59
mudb8
mudb8's Avatar
I have pics... still on the camera, I've been so busy lately I just haven't had the time I used to. I'll get to it soon...
Unread 08-24-2010, 10:23 PM   #60
rs4race
mudb8 thanks for the reply to that question. Ive actually talked to the guy who owns the jeep and I need to talk to him again soon. We talked about doing something similar to my rig and he will help with the welding. I like the idea of what you just posted. How does that effect access to the lower control arm bolt? I will be waiting for some more pics too.
My Build
