low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > low lift, long shocks, and DIY shock shifters... what's the advantage?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-01-2009, 08:47 AM   #16
CCJ
Great thread Mud!
CCJ is offline   Reply With Quote Quick reply to this message
Unread 10-19-2009, 05:06 PM   #17
cheapjeep06
[quote= so..... what did we accomplish here with a 2.5" lift and 24.25" long extended, 14.25" collapsed shocks?
it's self explanatory if you can read a tape! they are measured at ride height... ya, no joke this is the advantage.. went from 2.75" uptravel to 4 5/8" without loosing any downtravel....QUOTE]
b8, just got done reading this thread, and don't mean to be a d***, but if you have a 10" travel shock, and you move the lower shock mount down say 2", this extends the shock 2", so you gain 2" in uptravel(if your shock was limiting factor), but you lost 2" of downtravel, right? Trying to grasp this as I have only a 2" spacer in rear but I have 4WD Hardware shocks that are for a 4" lift. I did this originally to make it easier to go to 4" lift later, but have decide it is high enough, so I need to make some of those relocator mounts. I extended the rear bumpstops by 2" as well, which was a big mistake, as I now have only about 3-3 1/2" of uptravel. This was before I ever heard of Jeepforum, btw. Thanks for any advice.
Also, I can flex my front far enough (more than in my avatar pic) that the spring will unseat by 1/2", but that's to be expected with them, huh?
Rustys blows big, fat camel nuts.
cheapjeep06 is offline   Reply With Quote Quick reply to this message
Unread 10-19-2009, 11:46 PM   #18
mudb8
want it rite or rite now?
mudb8's Avatar
they are mounted outboard so, so yes, you loose some downtravel but no where near 2", the axle articulates in a radius, not straight down.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 12:24 AM   #19
CCJ
QFT 10 char
Unread 10-20-2009, 01:47 AM   #20
Boodyrider
As always... nice work, and great documentation.
I'll probably get off my butt and ask you for the pattern when I order the RC 2.5/2.2 lift that's in my future. I'll ASK for the longer shocks to get the benefits you espouse here.
It should be interesting and functional even that low and inexpensive; I just stuffed the trans and tcase up well above the frame rail. I was shooting for a dead flat to the frame belly, but ended up about 1 1/16 below the frame at the bottom of the plate. Could been higher, but I wanted the trans support separate from the armor.
I got a question for ya Mudb8.. Pm if preferred, it's off subject. What are the consequences of a front stretch? I went out about an inch, and noticed my 33s neatly removed the floaties from my bumper, but what else happens? With the belly-up (probably close to 4.5 inches at the front of the tcase), am I getting too close to pulling the front stock shaft splines out? - still stock height - just flat fenders to clear the 33s and a 1" MML/BL.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 01:46 PM   #21
mountaineerjp
Can you take some more pictures of the lower mount? I am getting ready to outboard my rears with Ford F250 shock mounts and need to figure out how I am gonna mount the axle side of the shock. And where did you get the shock stud for that mount?
1997 Sahara - 2.5"OME HD Springs and 2" BB - Bilstein 5100s - 35" BFG KM2s - Doug Thorley Header - Warn M8000 - Nates 4x4 Front & Rear Bumpers - JeepMedic Engine Skid - Shrockwork Rockers - OR-Fab Sport Cage - Ford 8.8 - 4.10s - TNT Customs 4.5" Tube Fenders in Front and Rear - Viking Soft Top - many other mods
WEST VIRGINIA UNIVERSITY
Every normal man must be tempted, at times, to spit on his hands, hoist the black flag, and begin slitting throats. - H. L. Mencken
mountaineerjp is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 02:02 PM   #22
1CleanTJ
what are the benefits are outboarding the rear shocks ?
1CleanTJ is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 02:07 PM   #23
Xlr8n
1986 TJ Wrangler
To allow fitment of longer shocks. Otherwise you're limited by the top of the frame/bottom of the tub being the highest mounting point.
Xlr8n is offline   Reply With Quote Quick reply to this message
Unread 10-20-2009, 02:17 PM   #24
mountaineerjp
when trying to build a low COG rig, you end up with shocks limiting your downward travel, or you have shocks that are too long and bottom them out entirely too easy
Unread 10-20-2009, 02:48 PM   #25
1CleanTJ
gotcha , i may look into doing that then
Unread 10-20-2009, 03:28 PM   #26
mudb8
mudb8's Avatar
Originally Posted by mountaineerjp View Post
[IMG]http://i268.photobucket.com/albums/jj17/mudb8-/shock%20relocation%20brackets/PICT00181.jpg[/IMG
yep, I have a pattern also for the lower mount I made, the shock stud is a 3/4 and 1 ton chev shock stud, 5/8" mounting, you can also get 1/2" mounting studs that are for use of 5/8 shock bushings from the front of 1/2t 2wd chevs.
I only use the short axle mounts for high clearance full outboard mounting or with short shocks...
not to mention stability
Unread 10-20-2009, 09:47 PM   #27
mountaineerjp
is that pattern by chance in a format that you can email or pm? no biggy if its not, just thought i would at least check. and where did you get those shock studs? junkyard? or did you order them from somewhere?
and thank you for the extra pictures
Unread 10-20-2009, 11:37 PM   #28
dbbd1
dbbd1's Avatar
Send him an envelope and he will send you a template.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2009, 12:45 PM   #29
mountaineerjp
and where exactly would i be sending this envelope
Unread 10-21-2009, 12:52 PM   #30
dbbd1
dbbd1's Avatar
You could send it Rob's offroad or PM him for an address.
Robs Off Road
-John Wayne
