low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 19 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > low lift, long shocks, and DIY shock shifters... what's the advantage?
Zone Offroad - Jeep Forum Promotion50% Off Sale at KrawlOff-Road.comJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 04-03-2014, 10:30 PM   #271
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by BamaJeepman21 View Post
Hey Mud, I recently put in my 2.5" rear springs and needless to say the shocks are a little long. As in I have 3" of up travel. New shocks aren't exactly in the budget right now so I was wondering if you could cut me a pair of these. I'd pay for the material cost and shipping.
I have several requests for mounts, I sent a pattern to be laser cut so i dont have to spend an hour on each pair. Still havent gotten them tho. Right now ive gotten myself in a little bind with too much work and am now behind on a bunch of stuff and a prototype suspension system i thought i could put together in a week on a daily driver, 12 days in now, should be done tomorrow... I cant promise anything, butt will try to get some done soon. I hope to have some laser cut brackets show up first tho.
To those i seem to keep stringing along, im sorry.
I had my boys cut and drill some a few years ago and had complaints so i quit having them help with hand cut parts.
Btw, if it matters... I sent a pair to canada about a couple months ago, the shipping alone via ups was 40 bucks, i put the worth at 10 to help with the taxes on the other end.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 04-07-2014, 12:35 AM   #272
BamaJeepman21
I might have ordered the wrong size shock. Mud, for rear RC 2.5" springs, and a 1.25" BL, would a 22.58/13.71 work well with minimum bumpstops? I'm afraid it'll still be too long.
Wanted: Savvy/Currie 3" front springs
-Jack
BamaJeepman21 is online now   Reply With Quote Quick reply to this message
Unread 04-07-2014, 11:48 AM   #273
mudb8
mudb8's Avatar
Those will need 2" extension if you have stock length upper/lower control arms. No modified pinion angle for a sye.
If you have shock shifters like the ones i recently posted, you will need more. Or bar pin eliminators, you need more.
Rc claims we cant hurt their shocks by using them as bumpstops. It will EVENTUALLY, mess up bar pins and possibly tear a mount off the axle.
Unread 04-07-2014, 11:56 AM   #274
BamaJeepman21
Is there a way for me to calculate how much uptravel I would have with that combo and those shocks?
-Jack
Unread 04-07-2014, 09:36 PM   #275
mudb8
mudb8's Avatar
At ride height, Bump the end of your tape on the upper mount bar pin, the measurement is at the bolt center of the lower mount.
Subtract the collapsed measurement of the shock you intend to use from that.
Unread 04-21-2014, 08:42 PM   #276
rusttech
front shock tower mod
I am planning on extending the front shock towers up 3" and outboard .52" to allow use of OME N66L shocks, which have splash shields on the shock shaft. Has 2" spring lift, fenders have been high-lined, no bump stop extensions are planned, has 33x10.50 tires on stock aluminum wheels as primary tire & wheel combo. Is this likely to work ok? I am afraid of shock shield clearance problems if I try using soup can type shifters as used by mud.
rusttech is offline   Reply With Quote Quick reply to this message
Unread 04-22-2014, 12:11 AM   #277
mudb8
mudb8's Avatar
I was running 34x12.5-16" tires on stock moab 5" backspace.
The dust shield can be cut off tho could be left alone if you use big enough "soup cans".
The ome n66L shock only needs to go up 2" to match factory bumpstops, more than that will over compress/ coil bind the springs.
Unread 04-22-2014, 10:36 AM   #278
UTWeezul
I was running 34x12.5-16" tires on stock moab 5" backspace. The dust shield can be cut off tho could be left alone if you use big enough "soup cans". The ome n66L shock only needs to go up 2" to match factory bumpstops, more than that will over compress/ coil bind the springs.
This the same for the N67L?
35" MTR Kevlars
TNT Phantom Fenders
PSC full corners w/ 3" flares
HP30 and 8.8 w/ lockers
UTWeezul is offline   Reply With Quote Quick reply to this message
Unread 04-22-2014, 11:45 AM   #279
mudb8
mudb8's Avatar
N67L depend on your mounts. They are 14" collapsed and can be run with 2" bumpstop extension, mounted in stock mounts, however, they will make contact with the spring pad and spring. shock shifters and pinion angle change the senario to the point you need to measure and cycle. For example, you are still running stock length upper/lower control arms and add a bolt on shock shifter (as shown in recent pictures above) to correct the problem of shock damages, you will then be in need of nearly 4" bumpstop extensions. By rotating the pinion for a slip yoke eliminator/double cardan drive shaft, with longer upper control arms the amount of required bumpstop extension DECREASES, as the shock bodies also get closer to the axle again.
So to the original question, yes.
Relocating the rear mounts, either the lower 2" down or the upper outboard, 2" higher, keeps you on stock length bumpstop extension.
Unread 04-22-2014, 12:59 PM   #280
Crawlmachine
Wondering if there are any updates on the axle brackets?
Looking for a "Grumpy" Front bumper for my TJ from Road Armor
Crawlmachine is offline   Reply With Quote Quick reply to this message
Unread 04-22-2014, 01:32 PM   #281
mudb8
mudb8's Avatar
I have a few laser cut pairs now, butt i dont like how they modified my pattern, they work great on those i flip and weld on tabs. I have been cutting the axle center line down lower on the ones i have installed which takes just about as long as i spend free hand cutting them myself.
Unread 04-30-2014, 08:10 PM   #282
RKCWLER
HLCLBER - TLCHSER
RKCWLER's Avatar
Mudb8, this is great! I have read this thread twice and I like what I see. My 04 TJ Rubi has the RE 3.5" standard lift (cv shaft and rotated pinion) with RE1365 rear springs. The RXJ704 rear shocks extended are 23.8", collapsed are 14.8" with 9" of travel. I would like to do the shock shifter with adjustment holes, that way I can replace with longer travel shocks in the future. I want to weld the brkt on in a position that would allow full out boarding, if I choose to go that route later. I can do all the lower rear shock shifter versions here with my plasma, welder and grinders. I can make the second version using the stock brkt and the measurements from your pattern, but there is no future adjustment doing it this way. Since you have made and worked on this, I ask for your opinion and suggestions. I have not seen the pdf pattern posted.
By the way, thanks for the info on the front tb mod. I still need to do a full stuff, but so far so good with uca mod.
><(((((((º>
Eat-Sleep-Fish
RKCWLER is online now   Reply With Quote Quick reply to this message
Unread 05-15-2014, 11:13 AM   #283
BamaJeepman21
Found out my rear Bilsteins are for a 4" lift. 25" ext, 15.41 col, 9.5" travel
Currently running those on 2.5" springs. Those will work perfect once I get these lower outboard mounts welded up.
-Jack
Unread 06-23-2014, 09:26 PM   #284
BamaJeepman21
Any updates on the mounts?
-Jack
Unread 10-01-2014, 11:29 PM   #285
mudb8
mudb8's Avatar
Some more variations....
11" balanced travel on 2" lift springs. Front bilsteins are 11.17", a jk application for 5-6" lift. Rear are 5125 11"
