low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > low lift, long shocks, and DIY shock shifters... what's the advantage?
Unread 09-28-2013, 02:27 PM   #241
mudb8
want it rite or rite now?
mudb8's Avatar
Welded tabs on ford towers....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 04:24 PM   #242
The_Dealer
2003 KJ Liberty
Damn that's clean.
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline   Reply With Quote Quick reply to this message
Unread 09-28-2013, 08:12 PM   #243
aparke4
Yep- I think I might need to get over it and bring out the metabo... Looking at some other posts it does not look like to big a section to take out.
aparke4 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2013, 08:51 PM   #244
yellowismellow
Custom User Title
yellowismellow's Avatar
Really wish unfinished reading this whole thread before I emailed you, mudb8.
Great discussion and learned a thing or two.
2006 TJ Sport
2004 WJ Special Edition
yellowismellow is offline   Reply With Quote Quick reply to this message
Unread 01-22-2014, 10:03 PM   #245
Leylands
I noticed the earlier style of lower relocation mounts created by mudb8 out of HSS used a bolt mounted at 90* to the axle, later posts changed this to re-using stock mounts instead which put the shock mount parallel to the rear axle. Doesn't the parallel "factory" style mount cause more wear and tear on the lower shock bushing as the axle flexes up and down?
Is one style better than the other over the long run? The earlier style of 90* bolt mount, although more work to fab up, seems to make more sense to me. No different than the upper relocation mounts rotating the shock 90*.
Leylands is offline   Reply With Quote Quick reply to this message
Unread 01-23-2014, 12:47 AM   #246
mudb8
mudb8's Avatar
I prefer the studs. The factory mounts welded to plates work as the factory intended them to and take me less effort. I use both depending on the amount of correction i need to get or if im just relocating to clear the spring pads, exhaust and tank.
Unread 01-23-2014, 12:53 AM   #247
mudb8
mudb8's Avatar
Unread 01-23-2014, 08:06 AM   #248
Leylands
That makes sense. This is a perfect fix for guys with limited build experience, but also those with experience who want a quick intern fix until they stretch and/or outboard later.
Any chance you can post a pattern for the HSS stud mount bracket?
Thanks!
Unread 01-23-2014, 02:53 PM   #249
mudb8
mudb8's Avatar
Heres a quick step by step...
Unread 01-23-2014, 03:01 PM   #250
mudb8
mudb8's Avatar
Thanks!
Unread 01-23-2014, 04:28 PM   #251
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
Any info on that sweet rig, MudB8?
Mail crawling.
MisfitSeven is offline   Reply With Quote Quick reply to this message
Unread 01-23-2014, 05:30 PM   #252
Leylands
Thanks for posting photos of your brackets It's hard to tell, but it looks like the upper coil mount is still in the factory forward position on your frame. Wouldn't the uptravel be improved with less coil bind by relocating the upper coil bracket level, towards the rear of the frame?
Unread 01-23-2014, 07:29 PM   #253
mudb8
mudb8's Avatar
That one still lands where its supposed to, currie arms, 3" bds springs. Customer rig built one thing at a time
Unread 01-23-2014, 10:10 PM   #254
mudb8
mudb8's Avatar
U mean the one sitting on the 42" pbr's?
Unread 01-24-2014, 06:24 AM   #255
MisfitSeven
MAiL Crawler.
Yes
Mail crawling.
