low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 7 - JeepForum.com
post #91 of 371 Old 11-09-2010, 11:49 PM
TheDragonfly
I want one too!
TheDragonfly is offline
post #92 of 371 Old 12-07-2010, 09:47 PM
emahan01
would u be willing to sell a set of weld on mounts i have a 8.8 im working on and figure i might as well put these on since my rc 2.2s are too long.
2.5 susp,1.25 body,aussie front 33x12.5 mud country, rokmen front,trail gear rear bumper, winch, straps
emahan01 is offline
post #93 of 371 Old 01-05-2011, 04:29 PM
UnsanePyro
Any news on the progress of the bolt on shifters? I certainly haven't lost interest.
UnsanePyro is offline
post #94 of 371 Old 01-06-2011, 12:17 AM
Blktjsport
Im in definate need of outboarding bracket that goes on the control arm bracket before I mess up my new bilstein 5100's. This will definitely be one of the best mods I'll do. Pm me mudb8 so I can get a set of weld one soon
2001 WJ -WIFES K&N FIPK~2.5" FLOWMASTER 40~2.5" BB~ BILSTEINS~ 255/70/18 BRIDGSTONE A/T JK'S
1999 TJ SPORT- NP242~SYE~K&N APOLLO COWL CAI~2.5" FM40 ~3.5" RE~ BILSTEIN 5100~D44~33" BFG MT~ DAVES RACK~ BUSHWACKERS~ HELLA ECODE DDM 6K HID
Blktjsport is offline
post #95 of 371 Old 01-06-2011, 06:13 AM
UTWeezul
I've got some that I made with his template and I'm running OME N67Ls and currently have 5" up and 7" down travel. Gonna get some upper mounts that move it up an inch so that I'll have 6 up and 6 down...or may even cut an inch off the bottom of the shock shifters for a little more clearance since my bumpstops are set at 4" of uptravel...
One of the best and cheapest mods I've done to the Jeep!
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #96 of 371 Old 01-06-2011, 07:21 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
I've been working on a 2011 E350 Van 4X4 conversion for about a month fabricating all the bracketry, Radius arms and fuel tank from scratch, so I haven't really done anything else other than a flat belly skid for my rubi last sunday.
I'll get back to the mounts tho for sure. As for sending out parts, I can't promise anything, I don't have any pre made and the last pairs my boys made (11 and 15yr) have some holes that weren't centered and got complaints so I won't send them out. I'm at the shop from 7am till 11pm 7 days a weeks as it is, time just flys by.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #97 of 371 Old 01-06-2011, 07:23 PM Thread Starter
mudb8
mudb8's Avatar
sweet, teraflex makes a BPE that raises the top mount an inch, a BL is required.
mudb8 is offline
post #98 of 371 Old 01-06-2011, 07:24 PM Thread Starter
mudb8
mudb8's Avatar
what is the part # on your shocks?
mudb8 is offline
post #99 of 371 Old 01-27-2011, 08:53 AM
MikalCarbine
Any updates on the bolt on shifters?
By the way, do you have any numbers on the difference of allowable travel between shock shifting vs outboarding?
MikalCarbine is offline
post #100 of 371 Old 01-27-2011, 09:14 AM
TheDragonfly
Interesting, Do you have a pic of how these mount?
"It is dangerous to be right when the government is wrong." – Voltaire
post #101 of 371 Old 01-27-2011, 10:55 AM
Blktjsport
Oh sorry mudb8 just saw ur post the bilsteins I have are part #Bilstein 5100 f4-be5-2732-h5 they r to long for my 2.5' sl so I only have like 3.25" of up travel so ur brackets would definitely be my only solution. Hopefully u can help me out thanks in advance
post #102 of 371 Old 01-27-2011, 10:56 AM
tucanbob
any update on selling these? I'm in need of more travel.
99 TJ - SOLD
running jeep-less for now.
tucanbob is offline
post #103 of 371 Old 02-20-2011, 01:10 PM
TheSlowDown
Hello Mudb8,
If I get the Clayton solution below, do you think I can go with the N67L long travel rear shocks versus the standard N66 OME shocks - (can down in both case)? The Clayton solution seems more in line with your original option # 2 for regular N67 shocks where you take the stock brackets, hack them off and weld them on in a more accommodating way.
What do you think?
TheSlowDown is offline
post #104 of 371 Old 02-22-2011, 09:28 PM Thread Starter
mudb8
mudb8's Avatar
the clayton mount would need to have the top lip hacked off and be mounted lower to run the N67L on a 2.5" lift, you can run the N67 standard travel shock with the mount relocation on stock suspension without bumpstop extension dependiong on where you locate the lower mount.
mudb8 is offline
post #105 of 371 Old 02-22-2011, 09:38 PM
TheSlowDown
Thank you for your advice.
Nth Degree/AEV Rear shock shifters sduncan TJ Wrangler Technical Forum 5 08-30-2009 10:41 PM
Shock Shifters and 8.8 TSWRA TJ Wrangler Technical Forum 6 10-18-2005 10:43 PM
bds shock shifters TSWRA TJ Wrangler Technical Forum 4 08-15-2005 02:10 PM
Doh!! Looks like it's time for some Nth° Shock Shifters wayoflife TJ Wrangler Technical Forum 6 02-14-2005 12:45 PM
