low lift, long shocks, and DIY shock shifters... what's the advantage? - Page 16 - JeepForum.com
post #226 of 368 Old 09-26-2013, 10:55 PM Thread Starter
mudb8
want it rite or rite now?
mudb8's Avatar
Originally Posted by J03_TJ View Post
Hmm, yep I see that those are symmetric. Thanks. Mine are the white Rancho 9000x, almost 10 years old. So you think the upper bushings took a set, and that's why they deflect differently between the sides?
My 9000's are about that age as well, they have formed to the mounts they are in. Still running original bushings also.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #227 of 368 Old 09-26-2013, 11:05 PM
BamaJeepman21
Originally Posted by mudb8 View Post
They are factory mounts welded to plate steel to span the ca mounts, i dont sell them, just something i do. It takes me about a half hour to get the mounts ready to reinstall once they are cut off the axle tube with a sawzall. I maxe up a pattern that takes the guess work out of the angle.
Just about all the tjs sold by the company i work with have some of my dumb ideas welded on bolted up or fliped over.. Rear shock mounts/damaged shock tubes and uptravel are a major peeve of mine.
Damn. I'd love to get a pair if you ever have any extra laying around...
-Jack
BamaJeepman21 is offline
post #228 of 368 Old 09-26-2013, 11:23 PM
aparke4
thanks for the pic mudb8- i need to snap a few of my set up and also measure to see how much room i have between the frame rail and tire. Last time I looked, mounting to the exterior of the frame was not an option for out boarding. I have already bought a set of f250 towers but have not gotten around to installing them!
aparke4 is offline
post #229 of 368 Old 09-27-2013, 10:11 AM
biffgnar
biffgnar's Avatar
Originally Posted by The_Dealer View Post
If I can find out if fox's bar pin can be removed, I'll flip the shocks can down and run the Tera top mount and gain that extra inch I need. I guess I still have some more searching to do
Is Wayne tuning the non-remote reservoirs? I didn't think so.
Romney in 2020!
biffgnar is offline
post #230 of 368 Old 09-27-2013, 10:40 AM Thread Starter
mudb8
mudb8's Avatar
I would stick with the ford towers!
Its pretty cool tho misfit had the balls to post that pic at the risk of being picked on...... One idea always sparks off another.
mudb8 is offline
post #231 of 368 Old 09-27-2013, 11:11 AM
aparke4
right on: if i could avoid cutting a nice, rust free 01 frame i would but looking at it today that aint happenin'.
aparke4 is offline
post #232 of 368 Old 09-27-2013, 11:54 AM
BamaJeepman21
This. Most people don't want to cut the frame and would much rather just weld on a tab.
-Jack
post #233 of 368 Old 09-27-2013, 02:43 PM
LittleBluE
Just remember, f250 towers and fox's don't jive.
LittleBluE is offline
post #234 of 368 Old 09-27-2013, 07:11 PM
The_Dealer
2003 KJ Liberty
why is that? That sucks, because when I do actually outboard, I was gonna do some f250 towers. I got a pair in the closet I was going to use on my bronco, but ended up selling it.
My build
http://www.jeepforum.com/forum/f22/the_dealers-soft-core-build-1476982/
The_Dealer is offline
post #235 of 368 Old 09-27-2013, 07:17 PM
TimV
It has to do with the way the top of the shock is shaped, vs what the mounting area of the tower is shaped like. There is interference between the two before the holes line up. I ended up making a set of custom towers for them when I did my outboard.
It's not an addiction. It's a way of life.
TimV is offline
post #236 of 368 Old 09-27-2013, 07:31 PM
biffgnar
biffgnar's Avatar
The Synergy towers do not have the clearance issues Ford towers do. Check them out.
Romney in 2020!
biffgnar is offline
post #237 of 368 Old 09-27-2013, 07:33 PM
The_Dealer
2003 KJ Liberty
I'm sure it shouldn't be hard to sell a pair of brand new towers
My build
post #238 of 368 Old 09-28-2013, 06:41 AM
rda616
I have been eyeballing these from Barnes. They are significantly cheaper than synergy mounts and look well made. Any one have feedback on these yet? https://www.barnes4wd.com/mobile/home.asp?#page-46
rda616 is offline
post #239 of 368 Old 09-28-2013, 08:09 AM
aparke4
The French towers and the behind the axle mounts for 100 bucks? Not bad!
aparke4 is offline
post #240 of 368 Old 09-28-2013, 01:25 PM
LittleBluE
For towers have clearance issues with fox's up in the mount. The only way to fit them is make your own, or use the polyperformance coil over brackets.
Nth Degree/AEV Rear shock shifters sduncan TJ Wrangler Technical Forum 5 08-30-2009 11:41 PM
Shock Shifters and 8.8 TSWRA TJ Wrangler Technical Forum 6 10-18-2005 11:43 PM
bds shock shifters TSWRA TJ Wrangler Technical Forum 4 08-15-2005 03:10 PM
Doh!! Looks like it's time for some Nth° Shock Shifters wayoflife TJ Wrangler Technical Forum 6 02-14-2005 01:45 PM
