#1 | |
Low Lift, High Travel 101
Ideal suspension on a jeep is to fit big tires, without a really high suspension lift and have a ton of travel.
What's the best way to go about doing something like this? Highline fenders, and a low LA kit? Just for a topic to talk about. ![]()
#2 |
technically if you could remove fenders all together, with a long arm setup and 40's you'd be golden. Unfortunatly thats not for all of us!
#3 |
Ideal suspension in who's eyes?
Personally, I'm not into the low center of whatever thing. Not interested at all. In my eyes 33's look right with 4" of lift. 35's with 5"-6" of lift. Whether its all suspension lift or a combination there of, doesn't matter to me 35's on 3" of lift does not look good to me, sorry. A few years ago 6" of lift was the norm. Now it's a new fad. It's cyclic and the LCG thing will probably fall out of flavor in a few years and I'll still be on RE 3.5" springs and won't have to do anything to be back in the "in" crowd. |
#4 |
Haha, I understand what you guys are saying. But i thinking about flatlanders Jeep. With the Dana 60's with 40" tires and he says it's only lifted 2-3" more then stock. Of course by the time my Jeep is like this it will be primarily a trail rig.
#5 |
build for where you wheel
however to stay on topic, ditch the fenders. cut the rear and make a mid arm lift with coil overs ![]()
Photographer at heart Have questions about something photography related? Click here!Like Coheed and Cambria? Join the club! My Jeep Build My Photography (New as of Jan. 25th) 1982 Motorcycle Build |
#6 | |
i believe he was talking function here! not fashion! |
#7 |
i wud talk to the rokmen guys they have a lg with 2.5 suspension lift on 40's short arm
#8 |
As far as this goes, it's something just more of a topic to talk about. Seems like it would be a pretty smart thing to do if anyone did it. I'm looking to learn more.
#9 | |
want it rite or rite now?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#10 |
Seems like 4" and 35's has become pretty popular lately. That's my current setup. I also prefer short arms for rock work.
#11 |
pshh thats nothing guys. Stock suspension, 1 inch body lift, 35s and metal cloak tubes up front
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#12 | |
-Justin | Bruised LJ Build |
#13 |
i think this is partly the point of the previous comment.
i made my fenders completely removable for wheeling. on the street its 35" AT and full fenders and flares. offroad its 36s and no fenders. with the coilover build in front it will be dropped around 1.5" and even larger tires. for me its less about the "LCG" thing but rather usable uptravel and usable clearance. |
#14 |
OK, I'm just rambling here and since I'm kind of a newb at wheeling I could be wrong, but it seems to me that if you set up your rig for low COG and you go over an obstacle on one side and you have limited up travel your whole jeep will rise on that side, as oposed to just the wheel/tire. That would actually raise your COG temporarily as you go over the obstacle, even though the tire on the other side drops and maintains contact. Not saying it's a bad thing, just food for thought. Am I wrong on this?
Carl[FONT="Arial"][/FONT] "[I]A Country Boy Can Survive"[/I] |
#15 | ||
Straight Up Fool!
Don't get me wrong, I'm not bashing LCG. And I'm not bashing long travel set ups. I'm just trying to imagine how the two can be done at the same time without massive amounts of custom fabrication. A lot of people like to claim that they can build a high travel LCG rig for pennies. Installing high line tubes and big tires may give you an LCG rig. And, if that's what you want that's great. But it doens't give you a high travel LCG rig. It seems to me that building a rig that is truly both high travle and LCG would be either complex, expensive, or both. Say a rig with said HL tube fender and long travel coil overs on custom mounting locations with long arms... you either spend a lot of time setting it up properly, or pay someone else a lot of money to do it for you...
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad I drive on the right side, what's wrong with you? Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
