Low cost, no cut, no drill LED install - JeepForum.com
post #1 of 36 Old 02-08-2008, 08:52 AM Thread Starter
Dragon158
I would have submitted this for a technical write up, but I posted it somewhere else first.
I've wanted to upgrade the tail lights in my Rubicon after the first week I owned it. But I did not want to cut a hole in a perfectly good tub, not after spending what I did for my low mileage 2004 Rubi. I shopped around but couldn't find a real no cut, no drill solution. So I came up with the idea to make my own tail light housings. I work as a heavy equipment/ diesel mechanic and began looking for something around the shop that I could use to fabricate my own custom housings. After a little thought I came up with a perfect & very cheap solution. A co worker had recently replaced an exhaust system on a large truck using 5" straight pipe and various elbows, he had to make a few cuts and had 2 feet of straight pipe extra. Before I did anything I did a test fit to see how the light and grommet would fit into the pipe, it was a near perfect fit. So I cut a 1 & 3/4" section from the piece of straight pipe, as seen below.
Then I had to fabricate a back for the housing, I cut a piece of 1/8" plate with the shop plasma cutter and made a 5" diameter circle.
Next I had to weld the newly cut circle to the 1 & 3/4" exhaust pipe section I cut earlier. I originally was just going to tack it in a few spots, because I thought I might have trouble getting a decent weld into the corners, but it welded pretty easy, so I did the entire piece. I also welded from the inside, because it needs to be smooth for the flush mounting. You can see it here after I painted it.
I removed the old tail light and used it as a template for drilling the mounting holes. I made both left and right housings at the same time so I could be sure that both would fit exactly how I wanted.
I had to cut the factory harness and wire in a new harness that I fabricated myself. It's pretty easy, 1 ground, 1 turn/brake and 1 running, for a total of 3 wires.
I was able to find small connectors in my shop to use to connect the new LEDs up with, but they can also be found at Radioshack. Because I had made the housing only 1 & 3/4" deep I had to cut and break the LED housing a bit. The new light was made to accept a plug, because the housing was so low profile a plug wouldn't fit, if I used the original plug the housing would have been 4" deep or better and it would have defeated the purpose.
I coated the back of my new fabricated housing with some silicone sealer, so it would act as a gasket and not destroy the paint under the housing after I mounted it. Then I installed them.
It was a pretty easy job, although it took me some time to gather up the parts and find the time to put everything together. I also installed LED reverse lights, I just cut 2 holes in the stock bumper and mounted them up. But I have yet to do anything about a tag light, I've been driving for 5 months now without one and have to get that done, before I get a ticket.
Here's a link to all the photos I uploaded, if you have any questions feel free to ask. Comments are welcomed, as this was my first real mod to my Rubi that didn't come in a box : )
LED Housing Photos
Dragon158 is offline
post #2 of 36 Old 02-08-2008, 08:59 AM
HTOR
HTOR's Avatar
neat idea! good job for thinking outside of the box
If you can build it, i will break it.
Team Crazy, and Mr Diameter Custom Machine.
"More Balls than you can shake your nuts at."
Jeep 1: 2000 Jeep Wrangler Sport - Its got goodies:)
Jeep 2: 1995 Jeep Grand Chero Limited - Its gonna go fast.
HTOR is offline
post #3 of 36 Old 02-08-2008, 08:59 AM
hazmat
Got any pics with the rev lights?
06 x, 4.0 6spd d30 and 44 4.10's tru tracs fr and rear. bds 3in lift ,skyjacker st stab. jks bl and bmml, jks discos, 33x10.5r15 bfg mt's on black d's, src r bumper/swingout,
hazmat is offline
post #4 of 36 Old 02-08-2008, 09:05 AM
Roughneck
Roughneck's Avatar
Really nice work! Wish I had access to a plasma cutter. I'd like to see a daylight pic, kinda close to see what the finished porduct looks like. I agree about not wanting to cut a hole into my perfectly good tub.
cheers, LT
2006 Rubicon Unlimited
Wranglers lead the way. I mean, Rangers lead the way!
Roughneck is offline
post #5 of 36 Old 02-08-2008, 09:05 AM
EvilM0nkey
EvilM0nkey's Avatar
can you take a side angle picture of the tail lights?
Great idea!
-Ross
EvilM0nkey is offline
post #6 of 36 Old 02-08-2008, 09:18 AM
Panici
(O|||||||O)
Panici's Avatar
I've been planning to do the exact same thing this summer!
_______
|_
_|
(OlllllllO)
Panici is offline
post #7 of 36 Old 02-08-2008, 10:42 AM
jcssurf
Doesn't that defeat the whole purpose of LED's? They allow you to flush mount, which protects them off road. Which still kind of seems like a waste of time to me.
But if you were just looking for some high performance brake lights, they're nice. And kudos on the low cost fab work.
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline
post #8 of 36 Old 02-08-2008, 10:58 AM
Zoom By You
Zoom By You's Avatar
Looks good!
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline
post #9 of 36 Old 02-08-2008, 11:03 AM
nyy845
wow, good job. I like that they are pretty low profile
nyy845 is offline
post #10 of 36 Old 02-08-2008, 12:26 PM
'B'wigstrailrig
I dont think using LEDs is about flush mounting. I hate that my lights look like the ones on my boat trailer.
'B'wigstrailrig is offline
post #11 of 36 Old 02-08-2008, 12:32 PM
wenkebach
wenkebach's Avatar
Excellent job! Where did you get the LED's, and how much did you spend on them?
2005 Wrangler Sport - 4.0L 6 speed
Rusty's 3" Lift, 33x12.5 Trxus MT's, JKS 1.25" BL, JKS BMML, Jeeperman Skidz
Jeeperman Bumper/Pre-runner Bar, Warn Winch, Front Aussie Locker
wenkebach is offline
post #12 of 36 Old 02-08-2008, 12:46 PM
probesport
probesport's Avatar
not bad, nice work
Ken S.
I'll find you someday and when I do, you'll know its me.
probesport is offline
post #13 of 36 Old 02-08-2008, 03:38 PM
beryl
a lot of people get them because they have torn up their stock lights because they stick out so far...but i agree, i like the look of the round lights much better.
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline
post #14 of 36 Old 02-08-2008, 04:01 PM
Zoom By You
I wonder if there is some type of 5" PVC or metal end cap, you could use, instead of having to make/weld the light housing....
post #15 of 36 Old 02-08-2008, 04:08 PM
opiv
opiv's Avatar
Nice work. You should start selling those as a complete kit before someone else does.Those don't look as easy to damage as the stock units since the housing is metal.
Get me my tools and beer.
opiv is offline
8.8 cost of install h2osprt YJ Wrangler Technical Forum 22 11-09-2008 12:35 PM
cost to install? Negative6 TJ Wrangler Technical Forum 3 06-19-2006 05:47 PM
RE 3.5" Install help ! How to drill a hole in the rear track bar bracket ? Humberto Benavides TJ Wrangler Technical Forum 1 09-29-2004 10:58 AM
BESTOP Drill-less Header Install Question yurmom22 TJ Wrangler Technical Forum 29 08-16-2004 03:18 AM
RE BB install cost JeepinJohnny TJ Wrangler Technical Forum 14 06-23-2004 10:22 AM
