louder exhaust - Page 2 - JeepForum.com
post #16 of 41 Old 07-14-2010, 05:13 AM
knightwolf654
cherrybomb pro or straight pipe. i had my muffler disconnected for a few days. and you cant hear your self speak when your accelerating
YouTube - Jeep Wrangler W/ Cherrybomb pro exhaust
knightwolf654 is offline
post #17 of 41 Old 07-14-2010, 07:53 AM
Jeeeps
Here's mine, cheap no name 2.5" cat back system with a high flow muffler and turned down tip:
cheers
Jeeeps is offline
post #18 of 41 Old 04-18-2011, 07:20 PM
guruleenyc
I just replaced my stock exhaust header/manifold after finding cracks all over with another stock manifold. However, I installed a Magnaflow High Flow catalytic with a Flowmaster Super 44 muffler and it sounds awesome! Very throaty, deep tones, a little crackling on de-acceleration and slightly louder than tires and noise on highway; doesn't over power stereo.
VERY HAPPY with sound, a [slight] performance improvement and appearance.
guruleenyc is offline
post #19 of 41 Old 04-18-2011, 10:05 PM
csmith
Cut off the tail pipe and put a turn down directly behind your muffler, you'll like it and it's a cheap upgrade to what you allready have.
csmith is offline
post #20 of 41 Old 04-19-2011, 07:52 AM
bseblfrk09
I have a flowmaster super 44 offroad series on mine. It sounds really good. nice and deep. Had a guy ask me the other day what v8 swap I did.
bseblfrk09 is offline
post #21 of 41 Old 04-19-2011, 09:09 AM
guruleenyc
Excuse my slight ignorance, can you be a little clearer what you mean by a "turn down"? Do you mean to cut it off after the catalytic and reattach to come out under or before axle?
Thanks!
post #22 of 41 Old 04-19-2011, 09:39 AM
jabroni3411
a turn down is basically a short downward facing pipe attached to the outflow pipe of the muffler. basically you dont have a tailpipe sticking out of the back of the jeep, the exhause ends after the muffler
Check My Build
jabroni3411 is offline
post #23 of 41 Old 04-19-2011, 09:41 AM
jabroni3411
the only real way to get a great sounding exhause, not just a loud muffler sound is by doing the whole set up...headers high flow cat and 2/3 chamber muffler or like a magnaflow straight through type muffler
Check My Build
post #24 of 41 Old 04-19-2011, 10:09 AM
adz4play
I had a vortex that was so loud it was iritating. Borla or monster all the way.....
adz4play is offline
post #25 of 41 Old 04-19-2011, 11:55 AM
05TurboS2K
Originally Posted by asknight View Post
Why louder? Louder doesn't mean more power.
Exactly. If I could get quiet and not lose power I always would do that.
05TurboS2K is offline
post #26 of 41 Old 04-19-2011, 11:58 AM
05TurboS2K
Originally Posted by Fropleyqk View Post
Why? Spend the money on something of value. People will notice a nicely built Jeep. And you wont get laughed at.
Great minds.
post #27 of 41 Old 04-19-2011, 12:04 PM
05TurboS2K
Generally speaking the worst thing you can do for performance is to change the length of the pipe in this manner.
The pipe length is criticle in the harmonics of the exhaust system to help the cylinder scavenging of burnt exhaust gases. By changing the length the system is ruined and you end up with burnt gasses in the chamber which means two things, more heat is the first, the second is less room for fresh air which has burnable oxygen.
For that reason I usually avoid chopping exhaust. Now if you're turbo then none of this is true as the turbo itself mostly stops the harmonic wave of exhaust but makes up for it by spooling the turbo.
post #28 of 41 Old 04-19-2011, 04:46 PM
csmith
I currently have a flowmaster installed on mine by the p.o. I just cut my tailpipe off behind the muffler and didn't loss any power. It definately is louder now. I have a banks system and a free flow cat to install as soon as I get my rear suspension tweaked exactly the way I want it.
csmith is offline
post #29 of 41 Old 04-19-2011, 04:54 PM
freeman84
I had a flowmaster 40 for a while and it sounded ok at best. It also was really loud in the cab and became very annoying. I now have a SpinTech Prostreet 6000 series muffler and it is great. It sounds amazing and really mean. Best part is it doesnt drone in the cab at all. I have had several people ask if I had a V8 under the hood.
Rubicon with Clayton, Currie, Poly Performance, Superior, Savvy.....and some others
freeman84 is offline
post #30 of 41 Old 04-19-2011, 05:00 PM
guruleenyc
Agreed, but there's budget constraints :-(
So I kept the stock exhaust Manifold and went with everything else. Loud and not annoying in my opinion. Had my mountain bike in the back with the hatch open and it was even louder to my surprise, which gave me a better idea of what it sounds like to others behind me... sounds like a 302 Mustang with flows! ;-)
exhaust , loud , louder
Cheap way to make your exhaust louder?? MusicMaverick YJ Wrangler Technical Forum 23 09-16-2010 02:46 PM
Looking for a louder horn goldsmith17 JK Wrangler Technical Forum 12 07-02-2009 10:25 AM
Louder Horn? AJ in Japan JK Wrangler Technical Forum 15 11-16-2007 07:19 PM
Cheapest way to Make Exhaust louder twinjeep97 TJ Wrangler Technical Forum 19 09-22-2007 10:43 AM
4.2 louder than 4.0 89_Sahara YJ Wrangler Technical Forum 6 04-25-2005 02:11 PM
