LOUD violent POP from transfer case on occasion from my lifted Rubicon transfer case - JeepForum.com
post #1 of 15 Old 07-11-2010, 10:17 AM Thread Starter
anymanusa
Hello. I just bought my first Jeep, I will make a thread as soon as I can load some pics, but right now I'm a little disconcerted by an occasional and loud "POP" that comes from the transfer case. This "pop" has come when I was shifting from reverse to 1rst, 1rst to 2nd, downshifting from 2nd to 1rst or just starting out from 1rst. This Jeep has been lifted 3.5", 2.25" of suspension lift, and 1.25" of body lift, and 1" spacers where placed under the motor mounts. I don't think anything has been done to the transfer case mount. The pinion angle looks pretty good, but it isn't straight line right now. The truck rides on 33's, and every time this "pop" has happened so far I was driving it in 2wd.
I plan on inspecting the transfer case for broken teeth but I haven't made it that far yet.
Any ideas? I need to figure this out before something breaks, if it hasn't already.
Thanks for reading.
anymanusa is offline
post #2 of 15 Old 07-11-2010, 10:22 AM
robncar
robncar's Avatar
How did you isolate it to the transfer case?
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 15 Old 07-11-2010, 10:24 AM Thread Starter
anymanusa
That's what it sounds like to me, judging from the sound and where it is coming from. I'm not 100% certain though.
post #4 of 15 Old 07-11-2010, 10:40 AM
Hella
My rubi transfer case seems to do this also but only in 4 low...so im curious
04 TJ "Leyla" Rubi..
Hella is offline
post #5 of 15 Old 07-11-2010, 10:46 AM
robncar
robncar's Avatar
Does it seem to come up from the floor pan, under the driver?
If so, it could be the transfer case shift linkage. On a stock TJ, it's mounted to the tub. When a body lift is installed the linkage can get bound up and pop now and them. The solution is to use an adapter bracket that moves the linkage to not mount on the tub, such as the Advance Adapters unit.
http://advanceadapters.com/product/2...r-Bracket.html
You can remove the rear driveshaft and drive on the front in 4-hi to attempt to isolate the noise.
robncar is offline
post #6 of 15 Old 07-11-2010, 10:52 AM Thread Starter
anymanusa
^^thanks. Now I have a starting point to work from. I will try that this weekend.
The sound seems to emanate from the right hand side, I hear it from the right hand side, not necessarily from 'directly' under the tub.
post #7 of 15 Old 07-18-2010, 02:57 AM
jmeeks83
Please let us know what you figure out. I've been having this exact problem with my '04. I've been told two or 3 different things by mechanics.
jmeeks83 is offline
post #8 of 15 Old 07-18-2010, 02:58 AM
jmeeks83
Oh... and I don't have a body lift.
jmeeks83 is offline
post #9 of 15 Old 07-18-2010, 03:58 AM Thread Starter
anymanusa
I'm still working on this. I've been granny shifting a lot lately and it's been much reduced in frequency and severity... still not sure why this is.
post #10 of 15 Old 07-18-2010, 05:15 AM
wushaw
Rockin jeep
wushaw's Avatar
Try pulling the rear drive shaft and run it in 4hi.
wushaw is offline
post #11 of 15 Old 07-18-2010, 05:56 AM Thread Starter
anymanusa
^^^thanks. I've marked the front driveshaft to see if it moves, i'll do what you suggest after I've checked that out.
post #12 of 15 Old 07-18-2010, 07:23 AM
Fropleyqk
Fropleyqk's Avatar
2014 JK Wrangler
The front driveshaft spins whether youre in 4wd or not. I might have missed something here....
Fropleyqk is offline
post #13 of 15 Old 07-19-2010, 01:35 AM Thread Starter
anymanusa
oh yeah, that makes sense. Oops.
post #14 of 15 Old 07-23-2010, 04:32 PM
jmeeks83
Believe it or not, mine was the control arms in the front end. I don't know how the sound traveled up that far but it did. Good luck
jmeeks83 is offline
post #15 of 15 Old 07-23-2010, 05:54 PM Thread Starter
anymanusa
It could be from that area. It's coming from the right front (I know that's not where the transfer case is). How did you figure it out and how did you correct it?
pop , noise , bang , transfer case , linkage , fix , help , rubicon
Two Probs, Transfer Case loud Knocking in 4wd and Changing outer axle shaft front YjShane YJ Wrangler Technical Forum 15 06-07-2012 10:09 PM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 02:28 PM
Rubicon Transfer case in a YJ? sebastian22 YJ Wrangler Technical Forum 8 07-10-2008 11:08 AM
Rubicon transfer case sdrubicon TJ Wrangler Technical Forum 6 04-27-2006 02:00 PM
HELP!! loud whine from transmission/transfer case ebolajackson YJ Wrangler Technical Forum 5 12-21-2004 06:22 PM
