loud squeeling noise when starting help please
#1 | |
When I start my 6 cyl 98 wrangler sport there is a loud squeling noise for about a minute and then it usually stops. The noise is worse when the air conditioner is on, but it still squeels even if the A/C is off...
Any ideas what this is? I recently had the serpentine belt replaced, do you guys think it may have something to do with the belt? I called the mechanic who put the belt on an he said that the tensioner may be going bad? Thing is that I did not have the squeeling before the belt was replaced.... Any suggestions on what may be causing the noise??? as always thanks for your assistance.....
#2 |
Sounds like the belt is loose... tighten it.
#3 | |
Brake Wizard
The 98 has a manually adjusted tensioner behind the power steering pump. You loosen the bolt in the center of the idler pulley just enough to let it slide and then turn the adjuster bolt right under the temp sender. Both are 15mm heads. Tighten it until the squealing just stops, which means you may have to test it a couple of times. Re-tighten between each test. The squeal is from the alternator pulley and the regulator telling it to top off the battery at start-up.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#4 |
Jeep
Your belt is loose and needs to be torqued down to increase the tension.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear 2.25" Suspension Lift with Old Man Emu Shocks Performance Accessories 1" Body Lift Daystar 1" Motor Mount Lift Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires |
#5 |
How do you know when you have the proper tension on the belt when manually adjusting it? Where is the power steering pump located?
#6 |
Also the squeel gets much louder when i give it "gas" (accelerate) ..
And there is a wheel that appears to be on the front of what i think is the air conditioning system. (the wheel is on the left side of the engine and is one of the wheels that the serpentine belt contacts. On the outside of the wheel there is a part that spins and stops frequently. When this wheel spins the squeeling begins and stops when the wheel is not spinning)...Does this mean anything different from the advice earlier to simply tighten the belt? Thank you |
#7 | |
Brake Wizard
#8 |
Squeeling
It could be the clutch itself on the AC. My 00 Cherokee had the same problem. I tensioned & then replaced the serpentine belt and it did not cure the problem then someone told me about the clutch going bad. From what I understand, it is easier to replace the whole compressor than the clutch alone. I never tried it though, got a truck to pull my boat. (I now have an 04 Rubicon). Hope this helps...
#9 |
Whatever you do... do not put any belt dressing on it!.. That stuff makes for a bad day!
Best Axles and service you will find. http://www.alljeep.com/oscommerce/index.php?cPath=32_617 The owner of Alljeep.com, Wayne Hartwig will work within your budget!!! He is very informative to anyone not knowing much about axle work and will meet or beat any competitor's advertised price on any specific product delivered to your door - even if he sells at cost! |
#10 |
it is funny that you say do not put belt dressing on it because alot of people are telling me to put it on there.
#11 | |
Jeep
#12 |
my 00 xj used to do that, but it always went away once the engine warmed up, i'm sure when my tj gets some more miles it'll start doing it
i just turned the hvac system off until it warmed up lol |
#13 | |
Jeep
#14 | |
Brake Wizard
#15 |
Yeah Mr. Blaine I did tighten it today and it seems to have worked lika a charm, no more squeeling.... Thank you for the advice it is greatly appreciated...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
