loud noise when I turn - JeepForum.com
post #1 of 5 Old 01-07-2005, 08:21 AM Thread Starter
97tj4.0
I am having a problem almost every time i drive my jeep now. when i turn, usually left, i hear a loud bang from the rear end. Do you think my differential might be locking up and if so what will fix it? thanks
97tj4.0 is offline
post #2 of 5 Old 01-07-2005, 08:30 AM
jonster
jonster's Avatar
2014 JK Wrangler
First, do you know if you have a locking diff. in the back. If so, they tend to make noise (clunking sound) when you make turns. Need more info.
2014 White JKUR
jonster is offline
post #3 of 5 Old 01-07-2005, 08:40 AM Thread Starter
97tj4.0
i'm not really sure. i have had the jeep for about a year so i don't know what all has been done to it. it just happens when i slow down and turn. it almost feels like somethings shifting around back there. it makes a loud pop. i recently had a 4in lift put on it, i thought maybe something had worked lose and was slipping back there, but i don't know.
97tj4.0 is offline
post #4 of 5 Old 01-07-2005, 01:15 PM
jonster
jonster's Avatar
2014 JK Wrangler
Here is a way to check to see if you have a locker installed. Check the rear axel. If you have a locker it will act like the discription following:
"Now as a final test, put the transmission in gear to lock the driveshaft. Next, have a helper rotate the passenger’s-side wheel (axle) in a forward direction until it stops and hold it. This side is now locked. Now, rotate the driver’s-side wheel in the opposite (reverse) direction. The Locker should click as the Coupler attached to the axle rotates. Now have your helper rotate the same wheel in a reverse direction until it stops and hold it. Now, rotate the driver’s-side wheel in the opposite (forward) direction and again you should hear the clicking sound. Have your helper change sides and perform the same test. If your measurements and tests have been successfully completed the unit has been installed correctly and you are now ready to install the differential cover and add the required amount of fluid."
This was for a "lunchbox" type locker like Powertrax. Hope this helps.
2014 White JKUR
jonster is offline
post #5 of 5 Old 01-07-2005, 09:51 PM Thread Starter
97tj4.0
thanks it is helpful
97tj4.0 is offline
loud noise when in reserve , noise when taking sharp right turns??? ReD-RuM TJ Wrangler Technical Forum 5 12-25-2009 08:15 AM
Loud POP when I turn Left redfishCT YJ Wrangler Technical Forum 1 09-22-2008 07:36 AM
Track bar making loud noise when I turn jimG16 TJ Wrangler Technical Forum 1 09-13-2008 06:23 PM
Loud Screech when I turn yjing YJ Wrangler Technical Forum 4 06-02-2007 12:15 AM
Loud pop/ thump when I turn? Steviet28 TJ Wrangler Technical Forum 3 08-25-2006 11:12 AM
