Loud noise in front when turn? - JeepForum.com
post #1 of 21 Old 01-31-2012, 02:11 PM Thread Starter
zenash22
Please could someone give me some advice -Jeep is making a very loud noise when I turn in driveway of make a sharp turn. Could this be a ball joint or a u joint? I had a chevy truck that had the same sound and ball joint broke front end was on the ground!
Sharp turns-jeep jerks like it is sticking
not sure how to discribe the tire sound it is not like a rock in the tire more like a uneven hum similiar to a train (but not as loud -an uneven sound)
PLEASE HELP!
Annie
zenash22 is offline
post #2 of 21 Old 01-31-2012, 02:14 PM
noodles5124
Cv
noodles5124 is offline
post #3 of 21 Old 01-31-2012, 02:45 PM
mateas
The jerking during sharp turns makes it sound like it's in 4 wheel drive (transfer case).
'06 LJ, Bestop Trektop NX, Smittybilt front/rear bumpers, 4" RC long arm lift, Currie HD steering, 35x12.50x18 Toyo Open Country MT's, 18x9 Fuel Hostage's, matte black special.
mateas is offline
post #4 of 21 Old 01-31-2012, 02:55 PM
jr03
Check the front axle ujoints I had one bad made a pop and kinda grabbed cap on ujoint was broke
jr03 is offline
post #5 of 21 Old 01-31-2012, 04:55 PM Thread Starter
zenash22
I dont know what a CV joint is? maybe u could direct me on this-so with all the different answers I am still confused-do I replace the CV, Ball joints,and ujoints?
zenash22 is offline
post #6 of 21 Old 01-31-2012, 05:06 PM
jr03
Cv joint is in the drive shaft(it is made up of ujoints). The axle ujoints are what I was refering to they are on axle shafts between the axle tube end and wheel. The ball joints are on the steering knuckles and connect them to the "C" on the axle tube. I would lean toward the axle ujoints especially if this occurs when turning. You'll have to check all of them to determine the source.
jr03 is offline
post #7 of 21 Old 01-31-2012, 05:09 PM
TJBrit
check your sway bar links. mine did the same thing and found the drivers sway link busted at the ball joint.
2006 Unlimited, 6pd 4.0L.
Modified
TJBrit is offline
post #8 of 21 Old 01-31-2012, 05:34 PM Thread Starter
zenash22
ok got ya now thank u
zenash22 is offline
post #9 of 21 Old 01-31-2012, 05:38 PM
merkchop
From you description, I do not get you having a pop or anything, is that correct?
If it is just humming when you are making a sharp turn, check you power steering fluid and make sure it is not low. Once the pumps get low on fluid they will hum or make worse sounds when you are turning. If that is the case you can sit still and not be moving, turn the steering wheel and it should still make the sound.
merkchop is offline
post #10 of 21 Old 02-01-2012, 05:20 AM Thread Starter
zenash22
Its not a pop-it is a loud thump(like something is breaking), when turning, or over a bump-sounds like front end is coming apart-power steering fluid is fine. The humming in the left tire is all the time(not an even sound going down the road) All this is happening on the left front.-was on a muddy road, front end was all over the place, even in 4wd-never had that happen before, even in the snow. Will check u joint-scared to drive it
zenash22 is offline
post #11 of 21 Old 02-01-2012, 06:57 AM
noodles5124
Deff sounds like a cv joint I had the same problem ended up need all new axles
post #12 of 21 Old 02-01-2012, 08:28 AM
jr03
The stock axles do not have cv joints, they have single ujoint at each outer axle shaft. I would also consider the wheel bearing and check all the steering linkage too while your checking the ujoints and bearings.
jr03 is offline
post #13 of 21 Old 02-01-2012, 08:47 AM
DerekXJ
This is a shot in the dark but..................a busted sway bar endlink?
Im assuming youve already been under there inspecting things though....
DerekXJ is offline
post #14 of 21 Old 02-01-2012, 10:51 AM
j_niko
2009 JK Wrangler
Before spending a ton of money of parts, make sure your not rubbing the turn stops. Are you by any chance running slightly bigger tires?
If so, just add a couple washers to the stops and see if that takes care of it.
2000 - Sahara
1997 - Sahara
j_niko is offline
post #15 of 21 Old 02-01-2012, 11:08 AM
RaggedOleMan
X2...maybe it didn't dis-engage, and you're still in 4-wd.
X2 The drive shaft doesn't care if you're turning, but the axle u-joints do...
RaggedOleMan is offline
ball joints , noise , noise when turning , steering , u joints
turn the steering wheel all the way and hear a loud squeaking noise neil11 TJ Wrangler Technical Forum 4 02-06-2011 01:02 PM
Loud Clunking noise from Front End WesFent TJ Wrangler Technical Forum 3 05-31-2009 02:24 PM
Track bar making loud noise when I turn jimG16 TJ Wrangler Technical Forum 1 09-13-2008 07:23 PM
loud snapping noise from front end jeepforfree YJ Wrangler Technical Forum 5 05-15-2005 10:57 PM
loud noise when I turn 97tj4.0 TJ Wrangler Technical Forum 4 01-07-2005 10:51 PM
