-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Loud noise in front when turn? (http://www.jeepforum.com/forum/f9/loud-noise-front-when-turn-1322304/)
zenash22 01-31-2012 01:11 PM
:confused:Please could someone give me some advice -Jeep is making a very loud noise when I turn in driveway of make a sharp turn. Could this be a ball joint or a u joint? I had a chevy truck that had the same sound and ball joint broke front end was on the ground!
Sharp turns-jeep jerks like it is sticking
not sure how to discribe the tire sound it is not like a rock in the tire more like a uneven hum similiar to a train (but not as loud -an uneven sound)
PLEASE HELP!
Annie
noodles5124 01-31-2012 01:14 PM
Cv
mateas 01-31-2012 01:45 PM
The jerking during sharp turns makes it sound like it's in 4 wheel drive (transfer case).
jr03 01-31-2012 01:55 PM
Check the front axle ujoints I had one bad made a pop and kinda grabbed cap on ujoint was broke
zenash22 01-31-2012 03:55 PM
I dont know what a CV joint is? maybe u could direct me on this-so with all the different answers I am still confused-do I replace the CV, Ball joints,and ujoints?
jr03 01-31-2012 04:06 PM
Cv joint is in the drive shaft(it is made up of ujoints). The axle ujoints are what I was refering to they are on axle shafts between the axle tube end and wheel. The ball joints are on the steering knuckles and connect them to the "C" on the axle tube. I would lean toward the axle ujoints especially if this occurs when turning. You'll have to check all of them to determine the source.
TJBrit 01-31-2012 04:09 PM
check your sway bar links. mine did the same thing and found the drivers sway link busted at the ball joint.
zenash22 01-31-2012 04:34 PM
ok got ya now thank u
merkchop 01-31-2012 04:38 PM
From you description, I do not get you having a pop or anything, is that correct?
If it is just humming when you are making a sharp turn, check you power steering fluid and make sure it is not low. Once the pumps get low on fluid they will hum or make worse sounds when you are turning. If that is the case you can sit still and not be moving, turn the steering wheel and it should still make the sound.
zenash22 02-01-2012 04:20 AM
Its not a pop-it is a loud thump(like something is breaking), when turning, or over a bump-sounds like front end is coming apart-power steering fluid is fine. The humming in the left tire is all the time(not an even sound going down the road) All this is happening on the left front.-was on a muddy road, front end was all over the place, even in 4wd-never had that happen before, even in the snow. Will check u joint-scared to drive it
noodles5124 02-01-2012 05:57 AM
Deff sounds like a cv joint I had the same problem ended up need all new axles
jr03 02-01-2012 07:28 AM
The stock axles do not have cv joints, they have single ujoint at each outer axle shaft. I would also consider the wheel bearing and check all the steering linkage too while your checking the ujoints and bearings.
DerekXJ 02-01-2012 07:47 AM
This is a shot in the dark but..................a busted sway bar endlink?
Im assuming youve already been under there inspecting things though....
j_niko 02-01-2012 09:51 AM
Before spending a ton of money of parts, make sure your not rubbing the turn stops. Are you by any chance running slightly bigger tires?
If so, just add a couple washers to the stops and see if that takes care of it.
RaggedOleMan 02-01-2012 10:08 AM
X2...maybe it didn't dis-engage, and you're still in 4-wd.
X2 The drive shaft doesn't care if you're turning, but the axle u-joints do...
The time now is 12:41 PM.
