Lost transmission fluid while driving, please help! - JeepForum.com
post #1 of 8 Old 12-05-2013, 01:50 PM Thread Starter
Misleduser
Hello
The other night I was drive up town when the transmission line on my 05 Wrangler popped off the bottom of my radiator. Judging by the trail of fluid left on the road I lost any drive immediately because the trail started less then 50 yards from the point where I ended up stopping. Anyhow I ran down to the gas station and bought a house clamp and some ATF, fixed the hose and put the fluid in and it drove again.
The next night however it was extremely cold and when I started it the transmission would not shift into drive. After I let it warm up for about 5 minutes it finally shift into drive and I checked the fluid level and noticed that I over filled the transmission.
My question is does it sound like I did damage to my transmission. thanks
Misleduser is offline
post #2 of 8 Old 12-05-2013, 01:58 PM
2jhanna
Did you put the correct fluid in there, ATF4?
jhanna
denton county, tx
2jhanna is offline
post #3 of 8 Old 12-05-2013, 02:00 PM
biffgnar
biffgnar's Avatar
This. Don't worry about the overfilling. Lots of us overfill our 42RLEs by a full quart to prevent fluid starvation at odd angles on the trail.
biffgnar is online now
post #4 of 8 Old 12-05-2013, 02:42 PM
2jhanna
One more question, how much fluid did you have to add ?
Or how low was it ?
jhanna
denton county, tx
2jhanna is offline
post #5 of 8 Old 12-05-2013, 05:18 PM
number40Fan
2014 JK Wrangler
Time for a rebuild. Sounds like you smoked the sealing rings on the forward clutch piston.
number40Fan is offline
post #6 of 8 Old 12-05-2013, 05:34 PM Thread Starter
Misleduser
Or how low was it ?
I added 2 quarts. Checked it its still slightly low.
post #7 of 8 Old 12-05-2013, 05:47 PM
2jhanna
Maybe someone else will chime in, but 2qts for a very short period doesn't sound like you would have done any real damage.
jhanna
denton county, tx
2jhanna is offline
post #8 of 8 Old 12-05-2013, 05:59 PM
durango-bob
2006 WK
Low fluid will act like yours. Top it off and you should be good.
durango-bob is offline
