-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Lost transmission fluid while driving, please help! (http://www.jeepforum.com/forum/f9/lost-transmission-fluid-while-driving-please-help-1860058/)
Misleduser 12-05-2013 12:50 PM
Hello
The other night I was drive up town when the transmission line on my 05 Wrangler popped off the bottom of my radiator. Judging by the trail of fluid left on the road I lost any drive immediately because the trail started less then 50 yards from the point where I ended up stopping. Anyhow I ran down to the gas station and bought a house clamp and some ATF, fixed the hose and put the fluid in and it drove again.
The next night however it was extremely cold and when I started it the transmission would not shift into drive. After I let it warm up for about 5 minutes it finally shift into drive and I checked the fluid level and noticed that I over filled the transmission.
My question is does it sound like I did damage to my transmission. thanks
2jhanna 12-05-2013 12:58 PM
Did you put the correct fluid in there, ATF4?
biffgnar 12-05-2013 01:00 PM
22 Attachment(s)
This. Don't worry about the overfilling. Lots of us overfill our 42RLEs by a full quart to prevent fluid starvation at odd angles on the trail.
2jhanna 12-05-2013 01:42 PM
One more question, how much fluid did you have to add ?
Or how low was it ?
number40Fan 12-05-2013 04:18 PM
Time for a rebuild. Sounds like you smoked the sealing rings on the forward clutch piston.
Misleduser 12-05-2013 04:34 PM
Or how low was it ?
I added 2 quarts. Checked it its still slightly low.
2jhanna 12-05-2013 04:47 PM
Maybe someone else will chime in, but 2qts for a very short period doesn't sound like you would have done any real damage.
durango-bob 12-05-2013 04:59 PM
Low fluid will act like yours. Top it off and you should be good.
The time now is 04:47 AM.
