Lost a screw and need help! - JeepForum.com
post #1 of 7 Old 12-04-2010, 06:04 PM Thread Starter
anorthrup
Today i was feeling ambitious and decided to replace my thermostat. All was going well until I dropped a screw behind the belt and now it is wedged behind them partially in the engine block. I can feel it but it is not budging. I am clueless how to get it out and am wary about starting to disassemble everything without any idea of where to start. Please help!
anorthrup is offline
post #2 of 7 Old 12-04-2010, 06:07 PM
2jhanna
take the belt off. that should help. all but the crank will rotate by hand.
jhanna
denton county, tx
2jhanna is offline
post #3 of 7 Old 12-04-2010, 07:07 PM
wushaw
Rockin jeep
wushaw's Avatar
Magnet??
wushaw is offline
post #4 of 7 Old 12-04-2010, 07:29 PM
Kenosha60
You should add what screw to your post header. Not just "need screw". Too vague. Lots of screws on a Jeep. Good luck.
Kenosha60 is offline
post #5 of 7 Old 12-04-2010, 07:31 PM
Kenosha60
P.S. Magnet for sure. If it's in there you can get it. Think positive.
post #6 of 7 Old 12-04-2010, 07:40 PM
ijp4fun
If you cannot get to it with a magnetic type tool, wrap some duct tape sticky side out on to some flexible wire to grab it, or If you have an air compressor, blow it out.
ijp4fun is offline
post #7 of 7 Old 12-04-2010, 07:46 PM
2jhanna
Doesn't really matter which screw, the OP is just asking for some help and ideas.
jhanna
denton county, tx
2jhanna is offline
help needed , screw
#T50 Torx Screw -Door Hinge Screw Replacement releve JK Wrangler Technical Forum 10 08-04-2012 08:01 AM
Lost screw that holds soft top frame to roll bar Tim04willys TJ Wrangler Technical Forum 3 08-04-2009 08:56 PM
Lost hard top screw/bracket shw104 TJ Wrangler Technical Forum 5 12-01-2008 02:17 PM
Just said screw it!!! BChamberlin Wrangler General Discussion 2 06-05-2008 02:39 PM
Lost my vibes, but I also lost 2nd gear?? pookie TJ Wrangler Technical Forum 14 01-23-2006 09:34 PM
