Lost Reverse suddently - JeepForum.com
post #1 of 6 Old 11-08-2015, 09:49 PM Thread Starter
DrBro
Driving around in the mud after a big rain. Found a creek that was too deep, so backed out. It wouldn't do much in 4HI so I shifted to 4Lo and it backed out fine. Drove off and then 5 minutes later shifted to reverse - nothing. Slight whine, shift to drive and it pulls ok. Is this a common failure for reverse?
DrBro is offline
post #2 of 6 Old 11-11-2015, 09:02 PM Thread Starter
DrBro
Hello - nobody else has had this problem with an auto tranny?
DrBro is offline
post #3 of 6 Old 11-12-2015, 12:36 AM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you looked at the condition of your transmission fluid?...
Knuckelhead is offline
post #4 of 6 Old 11-12-2015, 06:51 AM
prjohnson
Yikes! I know where this is going....
Seems like I read this a few times a year. You got in water that was too deep, water entered your vent & ruined your transmission. You can try to flush & fill your transmission (few have had successful results), but most likely a rebuild is in your future.
prjohnson is offline
post #5 of 6 Old 11-12-2015, 12:51 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
I had tens of quarts of fluid flushed through my 32RH before it was clean and it's still ticking. Those things can take a licking but I'm not sure if your 42RLE has the same ability to take a beating, but there is a chance!
The next thing you'll want to do is extend the transmission breather up into the engine compartment. I have my zip tied to the top of the fire wall.
As mentioned, check the fluid and do a flush if necessary. Good luck!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #6 of 6 Old 11-14-2015, 07:16 AM
ppap
I went through the same thing a few months ago. Pull the dipstick and smell the fluid. If it smells burned, regardless of the color (mine was pink/red), the reverse clutch plates are wasted. The only solution was a replacement or rebuild.
ppap is offline
