loss of power - JeepForum.com
post #1 of 12 Old 10-21-2003, 10:04 PM Thread Starter
echoes
loss of power
Need help. My Jeep, after driving it on the highway for about 10 minutes, will start to lose power. It seems as if there is no gas getting to the engine but, there is no sputtering. It idles fine but when I try to take off again it loses power. I'm thinking it is either the fuel pump or the coil. I think I smell something burning but the smell is very week. Also, I took it to the shop and had it hooked up to the computer and they said they found no errors. Any ideas on what it could be
echoes is offline
post #2 of 12 Old 10-22-2003, 06:26 AM
joeyprice
joeyprice's Avatar
2014 JK Wrangler
There seems to be a lot of this going around. There are quite a few possible causes discussed here.
I'd start with teh 02 sensors and then start throwing darts.
http://www.jeepforum.com/forum/f9/sensor-problems-again-54685/
joeyprice is offline
post #3 of 12 Old 10-22-2003, 07:16 AM Thread Starter
echoes
o2 sensors have already been replaced. So has the TPS.
echoes is offline
post #4 of 12 Old 10-22-2003, 08:16 AM
nxsTJ28
nxsTJ28's Avatar
I was having a similar problem only it would happen after driving for about an hour. I changed the O2 senor and the problem still occurred. After that I reset the computer (because I forgot to do so when I replaced the O2 sensor) while I took the distributor cap off and cleaned the rotor. I made a two hour trip without any problems.
I've also read that someone had a similar problem and it turned out to be their fuel sending unit was getting hot and sucking up air.???
I like what someone said above, just start throwing darts.
Good luck.
nxsTJ28 is offline
post #5 of 12 Old 10-22-2003, 09:52 AM
blk97tj
blk97tj's Avatar
2014 JK Wrangler
I'm having the same problem right now. I've read that it could be O2 sensors, fuel pump, etc. but if the O2's are bad wouldn't i get a check engine light? My light has never come one so i'm really not sure what to do about it
2014 Wrangler Unlimited
4" lift on 35's
blk97tj is offline
post #6 of 12 Old 10-22-2003, 11:47 AM
nxsTJ28
nxsTJ28's Avatar
My light never came on and no codes posted either, however since I changed the upstream O2 sensor and reset the computer I haven't had any problems.
nxsTJ28 is offline
post #7 of 12 Old 10-22-2003, 02:47 PM
Jim Shanks
Jim Shanks's Avatar
I want to say I read an O2 sensor can die slowly and not post any codes. It's if it senses a drastic change that it will tick off the PCM. Do you have access to a scan tool? If so try hooking it up to see if the o2 sensor(s) are failing on you. Another thought is mine run like crap when I had an exhaust leak.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Jim Shanks is offline
post #8 of 12 Old 10-27-2003, 09:01 AM
blk97tj
blk97tj's Avatar
2014 JK Wrangler
alright, i just figured out that my jeep only does this when i get below half a tank of gas...would that mean that the fuel pump is going out or what?
4" lift on 35's
blk97tj is offline
post #9 of 12 Old 11-07-2003, 12:05 PM
Chackbay Cajun
Having similar problem,
My guess is that the decreased hydrostatic head from the lower fuel level is causing a weakened fuel pump to produce less pressure than is necessary to keep the fuel flow rate up.
I have a long explaination on one of my other replies....search for it if youre interested....I'm tired of typing.
later,
steve
Chackbay Cajun is offline
post #10 of 12 Old 11-07-2003, 06:17 PM
DirtyRedTJ
DirtyRedTJ's Avatar
Certainly sounds like a fuel pressure problem. It may be the fuel filter, pump, or some flow problem in the line or injectors. Just pick one and start.
DirtyRedTJ is offline
post #11 of 12 Old 07-31-2006, 12:24 PM
quigtj
Watch the playoffs!
Similar Problem
I started having a similar problem. Got down to about 1/4 tank and it would just cut off. Starts right back up, but happened a couple of times more. Put gas in and it's got no problem. Like a previous post, it doesn't seem to sputter (at least not for long <1 second), so it doesn't feel like the fuel is cutting out.........
I only had to put in 15 gallons in a 19 gallon tank, so there was "plenty" of gas in there.
Thanks!
Edit: just noticed the previous post is 3 years old...funny
'97 TJ Sahara, Black, 4.0L, 5SPD, Line-x
quigtj is offline
post #12 of 12 Old 07-31-2006, 06:58 PM
Rule303
A lot of people notice smells when the cat goes bad.
Rule303 is offline
Still loss of power Iamjr TJ Wrangler Technical Forum 9 01-14-2010 07:32 PM
power loss dw9301998 YJ Wrangler Technical Forum 7 07-11-2009 10:03 PM
Someone Help Me, Loss Of Power cardinalsfan06 TJ Wrangler Technical Forum 19 03-03-2006 10:12 PM
Need some help here...power loss.... markburtenshaw YJ Wrangler Technical Forum 5 12-11-2003 12:45 PM
Power Loss Crawlin'Ken TJ Wrangler Technical Forum 2 05-21-2003 12:40 PM
